I have a WD PR2100 NAS that had two 2TB WD Red drives, in RAID 1 mode. The drives are fairly old now, and I needed extra space (had about 380GB left and I use PLEX), so I purchased two 4TB WD Red Pro drives. I attempted to rebuild the mirror by removing drive two (old) and replacing with a Red Pro.
After the auto-rebuild, the volume was downgraded. I do not know if data made it to the new Pro drive.
After many gyrations and a few days, and much web searching (turn off cloud, do the upgrade “this way” etc.) I’ve concluded WD is seriously missing the boat in providing an easy method, app, apk or whatever to assist people in upgrading the storage space of their NAS machines…seriously fubar here…wth?
So…I decided to remove both old drives, insert new drives and RAID them - and it works - everything is stable.
Except my data (I hope) are on the old drives. So, I am researching what external drive enclosures to purchase (any suggestions) and know how to boot into Ubuntu on a spare laptop…
But if I do this, will I access the data? Will I have to re-setup my shares or can I copy the drive directories as they are? Should I hook the NAS directly into the laptop via ethernet instead of sending data over the router? With this much data, I am wary of wifi clogging down eventually, losing bytes…
Or if I connect the external drive to the NAS USB, will the PR2100 be able to read the data and move it to the NAS?
Lastly, is it possible, now, to remove a drive in the NAS, replace with one of my old drives, and it can rebuild the volume? I am not even sure of the RAID made it to both old drives (many attempts, all ended in “degraded” - but the copy process itself seemed to have finished…?).
Suggestions on what to do? Pitfalls? I am not an IT expert, but am certainly better versed than the average bear - I can run SSH command lines if needed (don’t really wish to relearn such things). All thoughts and suggestions welcomed…
And shame on WD - this process should had been well documented - I can’t find it - if it exists it should be prominent…easily searchable and found…way to much confusion on many posts. I need help with this, and I understand it much better than many people…you do want to sell upgrade drives right?
