WD Caviar Blue 500Gb clicking sound
I’ve defragmented my hdd the other days and after I’ve noticed a faint continuous clicking sound ( like clic - clic - clic ) when it was idle. After a while it went away. When I did a hdd benchmarking test the clicking reappeared and again after a while it stopped.
It’s not a loud clicking noise, it’s the same as the normal hdd sound but it’s regular and you can hear it even when you’re in BIOS. The reason I am asking is because I’ve read about the ‘click of death’ and I don’t know exactly if this is my case.
I’ve done some disk checking tests and all came out ok.
Anyone else had this issue ?
I would backup any important files first and then do a test with DLG, follow the link below.
http://wdc.custhelp.com/app/answers/detail/a_id/940/session/L3RpbWUvMTM0NjYwNjU3Ni9zaWQvUXAyWm1mNWw%3D
I did that test also, came out fine. Also, I’ve noticed that this pattern comes up only if I benchmark stress the last partition on the hdd.
