@htb The issue is not that phpMyAdmin cannot support remote access. The issue is that the database server itself cannot be accessed by clients. Which makes the NAS unusable for media server applications, especially with Kodi clients using the NAS as the mysql server.
WD made the right call to close down external access to internal management DB
For those in need of an MySQL server, you can always run a second instance on another port.
Either by simply using the builtin daemon binary with your own config, or you can get a more recent version via Docker or Entware (both available in Community Developed Apps - WD Community).
All you need to do is adjust the listen address and port.
The docker / entware routes are persistent over reboots.
Based on Docker and Docker
Create docker-compose.yml somewhere on a persistent location.
# Use root/example as user/password credentials
version: '3.1'
services:
db:
image: mysql
command: --default-authentication-plugin=mysql_native_password
restart: always
environment:
MYSQL_ROOT_PASSWORD: example
ports:
- 3307:3306
phpmyadmin:
image: phpmyadmin
restart: always
ports:
- 8080:80
Then run
docker-compose up -d
Bamn. 2 steps, without turning your NAS into a honeypot.
Welcome to 2020.
No its absolutely impossible to revert back to OS3
My Cloud OS 3 to My Cloud OS 5 FAQ
Yes I feel you Iām effing done with WD. Poor rollout of OS5, bad engineering lousy customer service. Theyāve become a terrible company. Iāll be switching to Synology. OS5 rollout so poor and destructive, I'm switching brands to Synology after much research
@Tfl Except that Docker isnāt installed in the new OS/5ā¦
If anyone is still in warranty then keep putting pressure on WD to send you a new device as OS5 is not letting you have the same functions as os3 so itās useless to some people or even limited.
It looks like that WD start to hate customers. Iām very upset about OS5 I loose mysql, the device is always turning around while doing indexing and creating nasyty previews I never used before.
So as shame on teh WD Product Owner. My next device is home build, sorry guys I nearly 30 years in that *nix business so I can do that, or I by a better product from an other company.
I personally am looking at turning my PR4100 into either OpenMediaVault or FreeNAS. There is a nice tutorial in the forums about using FreeNAS on the 4100.
Daryl
Thanks for your help. You can easily add a crontab to exeute this commands:
Type in command line:
- crontab -e
add following lines:
@reboot echo ā[mysqld] bind-address=0.0.0.0ā > /etc/my.cnf
@reboot python3 /usr/bin/mysql_reset.py --reboot
This means, after the reboot this two commands will be executed. I hope this will help you.
Unfortunately, these changes wonāt persist after reboot. The crontab is copied over from a persistent store.
Looks like they finally fixed the issue⦠firmware 5.10.122
Accessing MySQL from outside of network : In todayās firmware 5.10.122, we have removed the restriction of restriction of accessing MySQL only from localhost. User can enable Network Database (MySQL) for remote access from the web configuration dashboard under Network Services. Please refer to this KBA .
Just looking around and found again another problem after had so many with a PR2100 and the update to cycloid 5. I had a power loop without the PR2100 was accessible on the lan, for weeks as they said it was doing diagnostic⦠then after so long I had a replacement and I sent my PR2100 with the hds (that had to be out in the replacement) and after some time I got a brand new PR2100 but with new hds, mine were thrown away on their process of recondition⦠this I just discovered week after they did, when I received the parcel. other weeks to try to find them somewhere (in spain laboratory in OntĆgola, well nothing to do⦠I wanted give the new pr2100 back! and after a week I tried to see if it was again an hw to use, so I spent time to set up and several things happened⦠a bay usb 3.1 with 4 hd, attached usb to the PR2100⦠some hds have been corrupted and I also discovered this phpadmin that does not work and probably so many others you all have hadā¦
I will take the 2 8TB hds and will make a tomb for the PR2100. and I will post this happening all over I could, because some strategies made from some of their white guys, have been closing the doors to freedom, and I will never more trust in such firms out there, just pushed of tech, but sipped, for make money and decide the use we could do. really going to use parts and assembling what it will work forever! shame on you WD!
In new firmware Update this has been fix
Go to Settings ā Networks ā change Network Database to āOn With remote accessā
