Hi, just wanted to introduce myself, my name is John, and I am a ok with computers until something goes wrong, and then I am just hopeless. I was hoping getting MY Clpud was going to help by putting things in one place, but its not really. I suppose it could be once I get it up and running properly. I am running Windows 10, and using Googe Chrome rowser. Both up to date.I have to say, everything was working perfectly until the change of ISP.
I am new to My Cloud, got it about a week ago. It seemed to be easy to set up, and it copied qute a few oders, with what seemed incredible speed. I have over a hundred iTunes films which were saved in hours.
I have two problems hopefully this will be the easiest to sort, I had to change my ISP a cuiple of days ago, and when I click on the WDMyCloud Icon, it opens up the UI. As soon as I click the link to log in it tells me there is a problem with the certificate, and it needs to be downloaded. Which I do, but it makes no diference. Whe I log out then back in again, I get the same message.
The second is a bit more complicated. From the bits of inormation I have read, and not understood really well. there is a problem with Qindows 10 and the folders added to the Windows Explorer. Well, There are folders scattered in different places, with nothing inside them. Plus, my Itunes tells me it can see WDMy Cloud but there is nothing in the folders.
I am pretty good at picking things up, but need a little bit o help getting there, otherwise, and as it stands, look through this orum, everything seems soo complicated.
Can somebody please help?
Thank you
John
