I have been running 2 units of MyBook Thunderbolt Duo side by side for nearly 4 years without any problems on my iMac. Both units are connected to both of my iMac’s thunderbolt slots directly and each unit has 2 removable disks, which are being striped with RAID 0 that gave me 6TB. All in all, I have 2 Thunderbolt duos, 4 Hard disks and 12TB of storage. Let’s now call this Thunderbolt Duo drives TD1 and TD2.
Recently, I have upgraded to Mojave and TD2 ejected by itself for no reason. When I rebooted it, it says that the drive A is missing. When I restarted it again, it says the RAID stripe set had failed. A later reboot tells me that drive B is missing. This error messages interchange whenever I reboot it.
Here is the strange thing. I had remove the 2 hard disks from TD2 - and place them in TD1. This drive rebooted without any issues with all my data intact. This means that there is absolutely nothing wrong with the hard disks. When I interchange the hard disks itself - TD2 behaves the same with the same error. What I don’t understand is, why did TD1 works and TD2 doesn’t? They are of the same configuration, same firmware and same hard disks - connected to the same iMac with same MacOS version.
I decided to replace the cables, alternate the ports on my iMac, switch the cables around and tried every possible combination. I just could not get TD2 to work properly again while TD1 works like a charm.
Can someone tell me what is going on with this Thunderbolt Duo Drive and how did I resolve it?
