Hi, i wanna ask. it’s possible connect My Passport Wireless Pro with Thunderbolt Cable for my Mac ?
Thank you and regards
Hi g_erwin,
WD My passport wireless pro comes with USB 3.0 Type-A cable. So, you can use a adapter to change the USB 3.0 Type-A to Type-C but the transfer speed will remains same as USB 3.0 5Gb/s ( 625 MB/s ).
Hi John15,
Thank you for your experience sharing
