Speed VERY slow WD My Passport 2TB
After about 11 hours, I only have 51% of 595 GB backed up to a 2 TB hard drive using a USB 3.0 port on Windows 10 machine. Tech disabled sleep and display turn off.
Does this seem excessively slow? Is it defective?
Sounds pretty slow to me :confused: … all of my WD Portable drives (Elements and Passports)
transfer rate is anywhere between 70MB/s to 100MB/s on USB3.0… mostly large files, small files (and a LOT of them) the speed does drop, but not too much.
Short Story: I bought a 2TB Elements Portable last week … first thing i always do is format new hard drives from “fresh” in this case i needed to format the factory format from NTFS to exFAT … anyways, after that, transfer speeds were as above (70~100MB/s)
Recommended to a friend to buy one (because they were cheap/on sale) … he then brought it to my house, i plugged it in, bu,t i did not format the drive for him … and i just started copying files for him.
Was shocked at how SLOW it was ! was getting between 10MB/s to 20MB/s ! … checked cables, tried different USB3.0 ports … no difference.
It was then, i said to him, i’ll have to re-format the drive as something strange is happening. Anyways, deleted the Partition Table and reformatted the drive to NTFS for him. After that … Speed was what i expected it to be ie. between 70MB/s to 100MB/s.
My advice,
Try using the drive on a different computer, or try a different USB3.0 cable or USB3.0 port
If no difference, then if you have a backup of your files/data
completely re-partition and re-format the drive (i use 3rd Party Software)
If it’s still snails pace slow after all of that, then dunno, sounds like it could be defective.
Thanks so much for the great feedback. I deeply appreciate it. I contacted WD support since it is brand new, but will add in your advice. Yes, something doesn’t seem correct.
