I attached a 1TB WD Mybook drive via USB to my 3TB Mycloud and using windows explorer (Win 7), I tried copying some video files to the Mycloud. I was only getting transfer speeds of 5MB/s and it took a while to work up to that from around 2.5MB/s. I then attached the Mybook to a USB hub and got transfer speeds of 11MB/s when copying files to the Mycloud.
Shouldn’t I be getting pretty good speeds copying directly from the Mybook to the Mycloud when they are directly attached to each other via USB?
Also, on another note, I am so loathe to do anymore firmware updates. The latest one downloaded and installed ok but after reboot, the drive showed the white light. I let it sit for about an hour and the WD dashboard app just showed the message “drive rebooting”. Finally, I unplugged the Mycloud and let it sit for about 20 minutes, and after plugging it back in, the blue light came on after about 10 minutes.
