Surely someone has the setup to build a deb out of a python application?
“Flexget” python source files: https://dl.dropboxusercontent.com/u/4883446/Flexget-develop.zip
im sure this will be useful for other also.
Could you please add aria2 to your repo?
Thanks.
Fox, I try to install transmission-daemon 2.84 from your sid and the error is as follows:
The following packages have unmet dependencies:
transmission-cli : Depends: libminiupnpc10 (>= 1.9.20140610) but it is not installable
transmission-daemon : Depends: init-system-helpers (>= 1.18~) but it is not going to be installed
Depends: libsystemd0 but it is not installable
E: Unable to correct problems, you have held broken packages.
Please assist.
Andy
I want.same
Вопрос.
Я все не могу поставить MC на клауд.
WDMyCloud:~# mc
mc: error while loading shared libraries: libgpm.so.2: ELF load command alignment not page-aligned
WDMyCloud:~# apt-get install --reinstall libgpm2
Reading package lists… Done
Building dependency tree
Reading state information… Done
Reinstallation of libgpm2 is not possible, it cannot be downloaded.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
WDMyCloud:~#
Можешь дать совет пожалуйста что делать.
Может если совета нет через скайп попробовать сделать с тобой починку этой проблемы, скажешь только сколько за твоё время нужно и какой акаунт пайпал.
с уважением.
Question.
I still can not put MC Claudio.
WDMyCloud:~# mc
WDMyCloud:~#
Can you please advice what to do.
If the Council can not try to do through Skype with you fix this problem, you say just how much of your time and what you need to account as Paipai Language.
waso_osa_cl wrote:
Вопрос.
Собственно, полностью снеси и поставь заново libgpm
Transmission from sid fixed. I think all dependences available now.
Tried using sid to install transmission-2.84 but get the following:
Depends: libcurl3-gnutls (>= 7.18.0) but it is not going to be installed
Recommends: transmission-cli (>= 1.50-1) but it is not going to be installed
Any help is appreciated.
Godwin
Transmission from sid can’t be installed because i can recompile libgnupg and some other packages.
Also PHP5 have unmet dependencies too (krb5 / Kerberos).
Maybe i fix it later
Thanks for the update and all the work you put into the MyCloud.
Hello
Could you please add lftp to your repo?
Great work, btw.
Hi, Fox_exe
When I try to install php5-gd, the following error information shown.
Could you please check it?
WDMyCloud:~# apt-get install php5-gd
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
php5-gd : Depends: phpapi-20100525+lfs
Depends: php5-common (= 5.4.35-0+deb7u2) but 5.5.11+dfsg-3 is to be installed
Hello Fox_exe.
My name is SUN, From korea.
Srry. Bad english… T.T
I have request to you.
plz ~~~~
plz~~
Can you write(teach) bubbleupnpserver install on v4 firmware?
plz~~~
Thank you.
Please add the following; git-core,cksfv,dnsutils,git,and telnet. Thanks !!
Please add “vim”
Thank you
I download the .deb file for rsync and trying to install it, but get this:
Preparing to replace rsync 3.0.9-4 (using rsync_3.0.9-4_armhf.deb) …
Unpacking replacement rsync …
Setting up rsync (3.0.9-4) …
Processing triggers for man-db …
fopen: Permission denied
im installing as root. WD drive running the latest 4.x fw
EDIT: Solved it by running: chown -R man /var/cache/man
Something to with the root user being the ownver of that directory causes the issue. Though i will put the ower back to root now, as i dont know the consequences of leaving it with a non root user.
Can you please send me the original sources.list file? I forgot to back up it.
Thanks…
Thanks…
If you meant the original sources.list from stock WD FW4.x then its below:
deb http://ftp.us.debian.org/debian/ jessie main
##deb http://ftp.us.debian.org/debian/ wheezy main
#deb http://ftp.us.debian.org/debian/ sid main
#deb http://ftp.us.debian.org/debian/ experimental main
#deb-src http://ftp.us.debian.org/debian/ jessie main
yes thank you should I paste the following to sources.list
Regarding my own post above. Does the stock sources.list show that the first “jessie” repo contains 64k page compatible?
Notice that, that is the only uncommented line in that file.
Note, wheezy is not 64K page aligned.
Yup
