Hi alirz1,
It should be since I’ve updated list with your stock sources.list and installed wakeonlan. It is working expected on V4.
Thanks again…
Hi alirz1,
Thanks again…
Hi.
Is repository dead? I was trying to do apt-get update, but there is a problem with host…
Problems with internet. Temporary offline.
Will back soon as possible.
If someone want share it: Full arhive
Or you can download it, unpack to any folder (Name it “dist” - its important)
And change apt list to (Example - Full path: /shares/Public/ dists /wheezy-64k/main/packages/)
deb file:/shares/Public/ wheezy-64k main
Привет.
Помоги плиз установить aria2.
Первым делом попытался установить 1.18 из SID. Получил следующую ошибку:
[MOD: Google translation]
Hello.
Help pliz install aria2.
First tried to install 1.18 from SID. Received the following error:
The following packages have unmet dependencies:
aria2 : Depends: libc-ares2 (>= 1.7.1) but it is not installable
Depends: libgnutls-deb0-28 (>= 3.3.0) but it is not installable
Depends: libstdc++6 (>= 4.9) but 4.7.2-5 is to be installed
E: Unable to correct problems, you have held broken packages.
Из основного репозитория 1.15 тоже ругается:
[MOD: Google translation] From the main repository 1.15 also swears:
The following packages have unmet dependencies:aria2 : Depends: libc-ares2 (>= 1.7.1) but it is not installable
Hi there,
Rsync 3.1.1 is out. Which is significantly newer and has some enhancements. Could you kindly build it for My cloud?
Thanks.
what about 04.01.03-421 version ?
can i use transmission directly or downgrade ?
which version can i hack to my cloud ?
This repo available for all v4 firmwares.
At some packages in SID dependences can be not available. I fix it later.
Also i try add transmission-daemon as backported package.
* Added chroot installer to first message.
* Build-essential & patched binutils (Soon)
* Samba v3? (I think its can run faster at PS=64kb)
For example;
İ want to install transmission for my cloud.
Only will i do your first message ?
Have you got a video about this topic ?
I am afraid of brick my cloud.
What about ps3netsrv, can i install it my cloud ?
Just install it from the other transmission thread by @nazar78
It’s easy and shouldn’t brick the drive at all
pyload is down in your repo…
WDMyCloud:~# apt-get install pyLoad
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package pyLoad
WDMyCloud:~#
pyLoad will come back online?
thx for help
hi.
i want to use ps3netsrv app on my cloud.
about:
PS3netsrv stream PS3 Iso thought your gigabit network to your PS3, usefull if your BD reader is dead.
the module on first install create a directory /raid/data/PS3_ISO, you have to create a share within the webui of your Thecus called PS3_ISO
the application listen on port 38008
the applciaction accept all device on netwrok (0.0.0.0)
http://www.ps3hax.net/showthread.php?t=64811
It needs to be built/compiled with 64K page size memory patch. but how ?
Great work Man
I have made a mirror to your Repository based on the last RAR file you have made
the Mirror Repository can be accessed from diaa.no-ip.com:8080
my mirror can be added using the following command
echo "deb http://diaa.no-ip.com:8080 wheezy-64k main" > /etc/apt/sources.list
let me know how can we sync up the 2 Repositories in an Automated way to give all the people access to your great work
No problems:
rsync -avr --stats anionix.ddns.net::wheezy-repo /var/www/dists
Fox_exe wrote:
No problems:
cool but i think i need to change
/var/www/dists
with the actual path of my dists ( the root of my Dists )
rsync: failed to connect to anionix.ddns.net (109.191.194.64): Connection refused (111)
rsync error: error in socket IO (code 10) at clientserver.c(122) [Receiver=3.0.9]
tried but did not work
rsync -avr --stats anionix.ddns.net::wheezy-repo /var/www/dists/
Oh, sorry, i open wrong port at my router
Now - works fine.
great synced and i have scheduled it to sync daily at 2 AM GMT
Now - works fine.
