My WDMyCloud 2T starts working ok after a boot, but in a short time “Refuses Connection”. At the same time it disappears from SmartWare.
Seems to be a commom bug here, but I can´t find a solution.
Content Scan gives an error, but I can´t know more about it.
It actually seems that apache2 and other services are stopping, since last time the problem worked I had enabled SSH and was unable to find apache with ps command.
When the system stops answering to internet, most of it is still running, since the command top in the terminal continue to show changes (apache disappears, though).
Some data about it:
Running v04.04.02-105
Blue Light is steady when systems stops
SSH enabled AFTER the problem to collect some data, no modification done
DHCP fixed in router
In /var/logs my Logs I can find some information that could be useful to someone, as in wdmcserver.log and apache2 errror.log, including a PHP fatal error.
wdmcserver.log (last log)
2016-04-10T11:08:20.501583-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
thrown from /data/workspace/workspace/wdmcserver_stable/src/util/Socket.cpp, line 403
2016-04-10T11:17:21.302411-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
2016-04-10T11:17:21.302519-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
2016-04-10T11:17:21.302576-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
2016-04-10T11:21:01.822058-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
2016-04-10T11:21:01.822157-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
2016-04-10T11:21:01.822200-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
2016-04-10T11:21:43.437103-03:00 di=NQQbWNid7v info wdmcserver: [7593:0x43d3f460] Error Broken pipe
Traceback:
apache server error log (selected lines), last time I booted and had an error
Sun Apr 10 02:26:22.342409 2016] [auth_digest:notice] [pid 4722] AH01757: generating secret for digest authentication …
[Sun Apr 10 02:26:23.422595 2016] [mpm_prefork:notice] [pid 4722] AH00163: Apache/2.4.10 (Debian) OpenSSL/1.0.1m configured – resuming normal opera
tions
[Sun Apr 10 02:26:23.423859 2016] [core:notice] [pid 4722] AH00094: Command line: ‘/usr/sbin/apache2’
df: /shares': No such file or directory df: no file systems processed df:
/shares’: No such file or directory
[Sun Apr 10 02:26:49.882299 2016] [mpm_prefork:error] [pid 4722] AH00161: server reached MaxRequestWorkers setting, consider raising the MaxRequestW
orkers setting
cat: /tmp/twonky_server: No such file or directory
[Sun Apr 10 02:27:48.709398 2016] [mpm_prefork:notice] [pid 4722] AH00171: Graceful restart requested, doing restart
[Sun Apr 10 02:27:49.384065 2016] [auth_digest:notice] [pid 4722] AH01757: generating secret for digest authentication …
[Sun Apr 10 02:27:49.872498 2016] [mpm_prefork:notice] [pid 4722] AH00163: Apache/2.4.10 (Debian) OpenSSL/1.0.1m configured – resuming normal opera
tions
[Sun Apr 10 02:27:49.872554 2016] [core:notice] [pid 4722] AH00094: Command line: ‘/usr/sbin/apache2’
getNewFirmwareUpgrade.sh: begin script: immediate
getNewFirmwareUpgrade.sh: http: //support.wdc.com/nas/list.asp?devtype=sq&devfw=04.04.02-105&devlang=eng&devsn=&auto=0&devid=*****
Enter new UNIX password: Retype new UNIX password: passwd: password updated successfully
[Sun Apr 10 02:34:31.535931 2016] [core:notice] [pid 4722] AH00052: child pid 8211 exit signal Bus error (7)
cat: /tmp/dev_fw_upgrade_link: No such file or directory
[Sun Apr 10 03:54:08.695597 2016] [:error] [pid 10431] [client 192.168.2.166:59170] PHP Fatal error: Maximum execution time of 30 seconds exceeded
in /var/www/rest-api/api/Filesystem/includes/mediavolumemgr.inc on line 343, referer: http://192.168.2.45/UI/
