I have just got the new Galaxy S4 android phone and i have tried to use my WD Remote app to control my WDTV. Now the app works, but the device slider at the top of the screen is not showing so you can’t slide it down and you can not tell when the device is connected as you can’t see the tab.
I am assuming this is because of the high res screen. A fix would be most appreciated.
Thanks.
