Problem with WD HD Player [GEN2]
It can not play mkv file it already 1.01.77
---------------- File Info -----------------
General
Format : Matroska
File size : 7.95 GiB
Duration : 1h 42mn
Overall bit rate : 11.1 Mbps
Encoded date : UTC 2010-10-14 06:58:10
Writing application : mkvmerge v4.3.0 (‘Escape from the Island’) built on Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 42mn
Bit rate : 9 363 Kbps
Nominal bit rate : 9 586 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.188
Stream size : 6.71 GiB (84%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-6 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9586 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Codec ID : A_DTS
Duration : 1h 42mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.08 GiB (14%)
It probably has header compression, which doesn’t work with any WDTV HD box, you’ll need to remux it.
Change mkvmerge v4.3.0 on mkvmerge v4.0.0 in mkvtoolnix no older version 4.0.0
How to change???
Sorry, use an automatic translator. Download program mkvtoolnix version
no older than 4.0.0 (it has a module mkvmerge GUI), upload your movie,
the program will show the composition of the rip, you can disable
the extra audio tracks and subtitles (uncheck) and just keep on your hard drive in the right place.
 The fact that WD TV works with the rip, which is used when creating a program mkvtoolnix no older than 4.0.0, but here the later version (in your media info the version 4.3.0). Hopefully, Google translator translated all right.
