update 03-21-11
you can download a folder to test
update : 03-20-2011 13:00
- put the counter away from the moviesheet (top of the screen now)
- change the overlay background (less dark)
- some adjustment in thumbgen template (global white roundcorner, tv episode thumbail brighter, remove the “episode” text)
update 03-27-2011I create a blue ray light theme (without fan art)
can be downloaded here : http://www.4shared.com/file/FHx428Gf/patate_-_blue_ray_-_light.html
hello
just share my work for people who want to test the The Tinwarble theme with a moviesheet (based on Joeysmith work)
the idea
a thumbgen template (fusion of Joey and Tinwarble with some own adds)
moviesheet for blueray rip
moviesheet for dvd rip
moviesheet for tv episode
sorry, it’s in french but you can modify it easily withe thumbgen designer
the Tinwarble theme modified by myself (copy in theme) :
all the view is fine now with the thumbhnail
it’s just a copy of tinwarble work and adding the last experience in listview of firetix (version 1.1) ).
http://www.4shared.com/file/lS5aFw4F/patatozor.html
folder to test : http://www.4shared.com/file/rOCg0hj1/patatotest.html
other views:
TINWARBLE WORK :
FIRETIX WORK
flickr link : http://www.flickr.com/photos/patatozor/sets/72157626294210692/
don’t forget to modify the option of thumbgen to generate a xml for live hub and a moviesheet with png extension
and at least
very very very big thanks to Tinwarble, Joeysmyth, psychothc,firetix,extremedigital and all the community of livehub for the accomplished word and their tolerance for my bad english :smileyvery-happy:
