Passport reset help
I forgot my passport password so I reset my passport and now everything that was on my passport when I first used it is now gone and I can’t get it back! Help Me!
If you can’t remember the password you’re out of luck. There is no reset. Hooking the drive up as an internal won’t work either.
Joe
