Old External Hard Drive - Cable Missing - Please Help! :)
Hi WD Community. I have a very old external hard drive and have lost the cable to connect it to my computer. The model number is WD800I032. I’ve included pictures of the drive. I’m not very savvy with these things - can anyone recommend where I can purchase a replacement? Thank you!!!
I recommend you contact WD Support to verify if they can assist you with this.
See if this helps identify the cable you need All Products: Shop Hard Drives, SSDs, USBs, & Memory Cards | Western Digital
Joe
You need this type … (it’s an older type USB cable which was used also with USB Printers)
Thank you!!
