No picture only sound on bluray mkv
HI There
I have an .mkv rip of the “main movie” from my bluray collection, with the dts-hd soundtrack (see media info below).
When trying to play the file with my (new) WDTV I can hear the audio (and I get the dts-hd light illuminated on my AV Receiver) however the screen is blank.
I have posted the media details below
Any ideas?
Format : Matroska
Format version : Version 2
File size : 16.6 GiB
Duration : 1h 5mn
Overall bit rate mode : Variable
Overall bit rate : 36.6 Mbps
Encoded date : UTC 2015-08-06 21:36:10
Writing application : MakeMKV v1.9.4 win(x64-release)
Writing library : libmakemkv v1.9.4 (1.3.0/1.4.1) win(x64-release)
Video
Format : AVC
Format profile : Stereo High@L4.1 / High@L4.1
MultiView_Count : 2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=24
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 5mn
Bit rate mode : Variable
Maximum bit rate : 30.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 5mn
Bit rate : Unknown / 768 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 5mn
Bit rate mode : Constant
Bit rate : 768 Kbps
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 357 MiB (2%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:17:55.365 : en:Chapter 02
00:27:14.758 : en:Chapter 03
00:42:06.899 : en:Chapter 04
00:44:09.563 : en:Chapter 05
00:48:32.409 : en:Chapter 06
00:57:14.347 : en:Chapter 07
01:03:57.834 : en:Chapter 08
Well that looks like you are ripping a 3D Bluray
Stereo High@L4.1 / MultiView Count (MVC) is not supported.
*WD TV Live products are not capable of playing frame sequential 3D *
*videos or newer 3D formats defined by BluRay or the extra enhancement *
extension from 3rd parties such as RealD
http://support.wdc.com/KnowledgeBase/answer.aspx?ID=9385
