Well, I’m into a 2nd day of success with the WD device! I still have the unit disconnected from the network and NO problem accessing my local content on the hard drive. I’ve been checking my network and I’ve turned off Windows Media server and checked all of my devices (including the TV, my smartphone, etc.) to ensure that DLNA is off. My receiver does DLNA and I would like to keep that on. I am going to reconnect the device to the network and give it a few days to see if I have solved the issue for good.
THANK YOU ALL FOR STICKING WITH ME TO HELP ME SOLVE THIS!!! (I believe I am very close.)
Awesome info! Thanks KAD!. I have a lot of DLNA servers running unnecessarily and had no idea that it might be the cause of some of my issues. This is really great stuff that you are bringing to the community.
Well, I thought I’d get back on to let folks know the latest… I’ve tried everything and can’t seem to find the issue in my network. The first thing I did was reboot my router and I immediately still had the same issue. I went to every device and turned off everything related to DLNA and nothing worked. Right now, I run the device disconnected from the network (and it works)…but I can’t access anything like YouTube… I just use it to access my photos, videos, music. I am convinced that it is an issue in my network, but I just can’t find it. (I haven’t given up completely…I’m just taking a break from it. ) Thanks to all for your help!
Any network switches involved and maybe the brand/model
I’m not saying the problem is with switches, but to those reading this, just to let you know that switches can get messed up, too. Once had a momentary power loss so brief it barely was noticeable. It fouled up two Linksys network switches. Theri brains got scrambled and slowed down the network to a crawl. I removed power from each for an appropriate time, and once reconnected they worked correctly again as they had for ten years before. So, when I reboot my network, I include switches, too.
I have a Linksys router… The WD device is connected via a small port switch which shares the single connection (directly from the Linksys router) with 3 other devices (a Foscam IP camera, a Samsung DVD player and an Onkyo Receiver). I didn’t “reboot” the switch before. I just unplugged it and re-plugged it in and reconnected the WD device to it. It will take me a day or so before I will know if this is the culprit. I might just buy a new one…or string a long ethernet cable from another room to test to see if I can get it to work. (First I will see if the rebooting works.) Thanks!
To add to this I had A switch that had one port that was partially working. So you might also change the port its plugged into on the switch.
Well, here’s the latest…I’ve rebooted my port switch (by unplugging it and plugging it back it)…I also switched ports. A day later, I had the same issue…so I unplugged everything from the switch except for the WD device. It worked for 2 days. Now I’ve plugged back in my receiver. It’s been working for 1 day so far… (the only 2 left are the IP camera and the DVD player…) I also order a new switch…should come in soon. So far so good… Thanks…
Well…it’s been some time since I’ve given an update. (I hope everyone had a great Thanksgiving!) I have since installed my new switch…and found that the culprit seems to be the IP Camera (a Foscam camera). It seems that whenever I install it, it causes issues with the WDlivehub device… Right now I’m keeping it unplugged but will investigate the settings much more closely there to see if I can get it to work WITH my WD device… Thanks again for all of the help.
