Help! Help! Help!1
How can I make password on my WD My Passport Ultra External Drive? Thanks in advance!
Use the “WD Security” tool which is part of WD software on your drive.
You can also download the WD Security for WIndows or for Mac from within the Download pages:
http://support.wdc.com/product.aspx?ID=232&lang=en
