Since recently I cannot access my Shares on my iPhone/iPad/wd2go when I’m not on my own WIFI.
on my iPhone I get the message “Device offline, only local files are available”.
Can anyone help me?
Thank you very much.
HansdJong
Can anyone help me?
HansdJong
See if this link will help.
What if you change the MBL mode to XP mode to force it to work on relay? Does that work? Some iOS 6.1.3 devices are having problems with the app unless the MBL is on relay.
