Green WD10EVDS giving trouble. Help needed understanding SMART info
Hi would some one please be able to help me make sense of this SMART info for my HDD?
Its a Green WD10EVDS.
Its used in a domestic satellite TV PVR. It was bought April 2011 and was working fine until Nov 2014. The PVR became slow and unresponsive. Running fsck on the HDD didn’t solve the issue. Replacing the WD10EVDS with a Seagate did.
But I’m a bit surprised that the WD is failing(?) so soon. The drive is specifically for PVRs and the PVR doesn’t get used excessively (~6 hours per day.)
I tried running the short and extended SMART tests but they abort after 10%. I don’t understand most of the SMART info below. Any help would be much appreciated. Thanks.
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.0-4-686-pae] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Western Digital AV-GP
Device Model: WDC WD10EVDS-63U8B1
Serial Number: WD-WCAVXXXXXXXX
LU WWN Device Id: X XXXXXX XXXXXXXXX
Firmware Version: 01.00A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sun Nov 2 17:54:58 2014
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84)	Offline data collection activity
					was suspended by an interrupting command from host.
					Auto Offline Data Collection: Enabled.
Self-test execution status: ( 121)	The previous self-test completed having
					the read element of the test failed.
Total time to complete Offline
data collection: (21180) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities: (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability: (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 244) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3037)	SCT Status supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate POSR-K 200 200 051 - 9
  3 Spin_Up_Time **bleep** --K 192 181 021 - 6400
  4 Start_Stop_Count -O--CK 096 096 000 - 4668
  5 Reallocated_Sector_Ct PO--CK 158 158 140 - 809
  7 Seek_Error_Rate -OSR-K 200 199 000 - 33
  9 Power_On_Hours -O--CK 085 085 000 - 11257
 10 Spin_Retry_Count -O--CK 100 100 000 - 0
 11 Calibration_Retry_Count -O--CK 100 100 000 - 0
 12 Power_Cycle_Count -O--CK 096 096 000 - 4667
192 Power-Off_Retract_Count -O--CK 194 194 000 - 4666
193 Load_Cycle_Count -O--CK 193 193 000 - 22764
194 Temperature_Celsius -O---K 117 090 000 - 30
196 Reallocated_Event_Count -O--CK 199 199 000 - 1
197 Current_Pending_Sector -O--CK 193 193 000 - 1288
198 Offline_Uncorrectable ----CK 187 187 000 - 2252
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 179 179 000 - 4221
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            ||| ____ S speed/performance
                            || _____ O updated online
                            | ______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
GP/S Log at address 0x00 has 1 sectors [Log Directory]
SMART Log at address 0x01 has 1 sectors [Summary SMART error log]
SMART Log at address 0x02 has 5 sectors [Comprehensive SMART error log]
GP Log at address 0x03 has 6 sectors [Ext. Comprehensive SMART error log]
SMART Log at address 0x06 has 1 sectors [SMART self-test log]
GP Log at address 0x07 has 1 sectors [Extended self-test log]
SMART Log at address 0x09 has 1 sectors [Selective self-test log]
GP Log at address 0x10 has 1 sectors [NCQ Command Error]
GP Log at address 0x11 has 1 sectors [SATA Phy Event Counters]
GP Log at address 0x21 has 1 sectors [Write stream error log]
GP Log at address 0x22 has 1 sectors [Read stream error log]
GP/S Log at address 0x80 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x81 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x82 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x83 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x84 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x85 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x86 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x87 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x88 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x89 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x8a has 16 sectors [Host vendor specific log]
GP/S Log at address 0x8b has 16 sectors [Host vendor specific log]
GP/S Log at address 0x8c has 16 sectors [Host vendor specific log]
GP/S Log at address 0x8d has 16 sectors [Host vendor specific log]
GP/S Log at address 0x8e has 16 sectors [Host vendor specific log]
GP/S Log at address 0x8f has 16 sectors [Host vendor specific log]
GP/S Log at address 0x90 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x91 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x92 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x93 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x94 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x95 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x96 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x97 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x98 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x99 has 16 sectors [Host vendor specific log]
GP/S Log at address 0x9a has 16 sectors [Host vendor specific log]
GP/S Log at address 0x9b has 16 sectors [Host vendor specific log]
GP/S Log at address 0x9c has 16 sectors [Host vendor specific log]
GP/S Log at address 0x9d has 16 sectors [Host vendor specific log]
GP/S Log at address 0x9e has 16 sectors [Host vendor specific log]
GP/S Log at address 0x9f has 16 sectors [Host vendor specific log]
GP/S Log at address 0xa0 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa1 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa2 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa3 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa4 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa5 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa6 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa7 has 16 sectors [Device vendor specific log]
GP/S Log at address 0xa8 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xa9 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xaa has 1 sectors [Device vendor specific log]
GP/S Log at address 0xab has 1 sectors [Device vendor specific log]
GP/S Log at address 0xac has 1 sectors [Device vendor specific log]
GP/S Log at address 0xad has 1 sectors [Device vendor specific log]
GP/S Log at address 0xae has 1 sectors [Device vendor specific log]
GP/S Log at address 0xaf has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb0 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb1 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb2 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb3 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb4 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb5 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb6 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xb7 has 1 sectors [Device vendor specific log]
GP/S Log at address 0xc0 has 1 sectors [Device vendor specific log]
GP Log at address 0xc1 has 24 sectors [Device vendor specific log]
GP/S Log at address 0xe0 has 1 sectors [SCT Command/Status]
GP/S Log at address 0xe1 has 1 sectors [SCT Data Transfer]
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 4
	CR = Command Register
	FEATR = Features Register
	COUNT = Count (was: Sector Count) Register
	LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
	LH = LBA High (was: Cylinder High) Register ] LBA
	LM = LBA Mid (was: Cylinder Low) Register ] Register
	LL = LBA Low (was: Sector Number) Register ]
	DV = Device (was: Device/Head) Register
	DC = Device Control Register
	ER = Error register
	ST = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 4 [3] occurred at disk power-on lifetime: 10726 hours (446 days + 22 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT LBA_48 LH LM LL DV DC
  40 -- 51 00 98 00 00 00 0f a7 ea e0 00 Error: UNC 152 sectors at LBA = 0x000fa7ea = 1026026
  Commands leading to the command that caused the error were:
  CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
  25 00 00 00 98 00 00 00 0f a7 ea e0 08 00:00:20.381 READ DMA EXT
  25 00 00 00 a0 00 00 00 0f a7 e2 e0 08 00:00:17.919 READ DMA EXT
  25 00 00 00 a8 00 00 00 0f a7 da e0 08 00:00:15.442 READ DMA EXT
  25 00 00 00 08 00 00 00 0f a7 d2 e0 08 00:00:15.440 READ DMA EXT
  25 00 00 00 40 00 00 00 0f a7 7a e0 08 00:00:15.407 READ DMA EXT
Error 3 [2] occurred at disk power-on lifetime: 10726 hours (446 days + 22 hours)
  40 -- 51 00 a0 00 00 00 0f a7 e2 e0 00 Error: UNC 160 sectors at LBA = 0x000fa7e2 = 1026018
  25 00 00 00 08 00 00 00 0f a7 72 e0 08 00:00:15.403 READ DMA EXT
Error 2 [1] occurred at disk power-on lifetime: 10726 hours (446 days + 22 hours)
  40 -- 51 00 a8 00 00 00 0f a7 da e0 00 Error: UNC 168 sectors at LBA = 0x000fa7da = 1026010
  25 00 00 00 08 00 00 00 00 04 22 e0 08 00:00:15.399 READ DMA EXT
Error 1 [0] occurred at disk power-on lifetime: 10705 hours (446 days + 1 hours)
  40 -- 51 00 08 00 00 02 29 89 4b e0 00 Error: UNC 8 sectors at LBA = 0x0229894b = 36276555
  25 00 00 00 08 00 00 02 29 89 4b e0 08 00:30:52.739 READ DMA EXT
  25 00 00 00 08 00 00 02 29 a9 93 e0 08 00:30:52.728 READ DMA EXT
  25 00 00 00 08 00 00 02 29 c9 9b e0 08 00:30:52.719 READ DMA EXT
  25 00 00 00 08 00 00 02 29 e9 a3 e0 08 00:30:52.715 READ DMA EXT
  25 00 00 00 08 00 00 02 2a 09 ab e0 08 00:30:52.701 READ DMA EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 90% 11252 36276124
# 2 Short offline Completed: read failure 90% 11252 36276124
SMART Selective self-test log data structure revision number 1
 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Error Read SCT Data Table failed: SAT command failed
Warning: device does not support SCT Error Recovery Control command
SATA Phy Event Counters (GP Log 0x11)
[Reserved: 0x34 0x40 0x50 0x00]
ID Size Value Description
0x0034 8 4626323061890875472 Unknown
0x0050 0: Invalid entry
Hello and welcome to the community,
Try running a diagnostic using WD DLG.
Hi, thanks for the welcome.
I tried using it but it stopped after about 10% saying there were too many bad sectors. I thought the fact the drive is EXT3 formatted might have been a problem for the windows based tool ?
Diagnostic tools such as DLG and smartmontools are independent of the file system. They test the drive at the hardware level.
The following attributes confirm that your drive has numerous bad sectors.
The Reallocated_Sector_Ct is reporting that 809 bad sectors have been replaced with spares, while the Current_Pending_Sector attribute is telling you that 1288 bad sectors are waiting to be replaced. IIUC, the Offline_Uncorrectable attribute is reporting that 2252 sectors have been assessed as bad during background scanning.
The following attributes should ideally have raw values of 0.
In short your drive is very ill and should be replaced ASAP.
Hi, fzabkar. Thanks for your reply - thats just the kind of info I was hoping for.
Wow - so it’s dying. Bugger! I had hoped a reformat would fix it.
Any idea what causes all those bad sectors and read errors? Defective drive? (It doesn’t matter to WD as I’m outside warranty, but just out of interest)
For some reason I expected more life from the drive, am I misguided on that front?(used for 3.5 years at about ~6hrs/day in a PVR)
