Hi guys, i need your help again with ex2 device
I am trying to enable FTP. I turned the function ON, i created a share with ftp access also for annonymous users. I also port forwarded the FTP service on the router ( ports 21, 990, 55536, 55663). I also forwarded the ports on the NAS
From browser, i can access via internet the FTP folder, but it shows empty, even if i have data in it.
From Filezila, i connect but i get eventualy this error
Status: Connection established, waiting for welcome message…
Status: Initializing TLS…
Status: Verifying certificate…
Status: TLS connection established.
Status: Connected
Status: Retrieving directory listing…
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: MLSD
Error: Connection timed out
Error: Failed to retrieve directory listing
Please advise…
PS: after hours of settings changing, i manage to connect ONLY via unencrypted FTP . No matter how much i switched between explicit/implicit TLS, i couldn’t get it to connect. It always stops at Reading the file directory
