Forced to reset
sinister13 wrote:
I’m on the verge of throwing this ‘new’ model in the trash and obtaining another (old) LIVE model.
Which most likely won’t help cause that freezing bugs  has been reported for the SMP as well.
…but the Live model can be fixed with a firmware rollback to 2.01.86, unlike this ‘new’ model.
unfortunatley we will have to wait for a new firmware update :cry:  hopefully soon
I have tried to see if there is a fix for this problem but as yet I haven:t had a response.
Best of luck because I dont think thay can replicate the problem.
What I do now to fix the problem which seems to work is turn the power off to the unit after use. Its no use using the remote to power it off it has to be switched off ot the power or unpluged.
Also reboot the network if the problem persiss because the more this problem occurs it appears to be a nework problem.
It will find its way around the network and even locate the file but refuses to play the Video, Music, or Photo regardless of wether its on a USB drive on the network.
Previous models didnt suffer this problem as I have 2 different older units both of which work.
