For WD MyPassport Write Protect Fix
Hello!! Soo just as i was getting ready to format my WD MyPassport Because of The Write Protect thin…I went to Check out Task manager and you can open it up many ways either pressing short cut ctrl + shift + esc or thrue windows search or thrue the command prompt if opened already!! anyhow as i was on my way to close some programs i noticed in the programs running list windows disk write protected…so i decided to end task for it and unplugged my passport and retried it and i was able to get it working again soo instead of going thrue all that formatting just open up task manager and end disk write protect task and you should Be set :slight_smile:
Hi @Justaaveragejoe,
Please refer below link to contact support for best possible solution:
https://support-en.wd.com/app/utils/login_form
