Fluctuation (low) read speed from SSD
WD 480Gb Green WDS480G2G0A.
From the beginning of its use, I noticed that it has a slow speed of READING information. Today in CrystalDiskMark - I tested it 10 times in a row and got different results from 15!! up to 460 MB/s (SEQ1M-Q8T1). I changed the cable. Dashboard.exe - shows that everything is ok (within what I can check). WIN 10, Latest firmware.
Please, tell me what could be the cause of the problem? What do I need to do to check and find the cause of this problem?
With the rest of the SSDs that I have in this PC, there is no such thing.
Hi @Savoy13,
Please refer to the article Common Causes and Solutions for Slow Network Data Transfer Speeds:
https://support-en.wd.com/app/answers/detailweb/a_id/15542
If further assistance is needed, please open a case with our support team at the following:
https://support-en.wd.com/app/askweb
