I’ve just got my new WDTVLSMP. I updated to the latest firmware (1.16.13) and things are pretty bad. I haven’t tested with previous versions.
I have a 1TB external disk, and when trying to “compile media” it freezes. I don’t have a problem while sharing network files, but since i don’t have a good router to stream HD files I’d like to keep my disk conected to the SMP.
The first time I connected the hdd it took ages (hours) to “compile” the information, then it kind of work, but then I tried adding more files to the disk and when i re-plug it it hangs. I don’t know why this is so slow, and why it freeze all the time… it is very annoying.
what do you think: is it a disk or firmware problem?
what do you reccomend for next steps? rollback the firmware, factory reset?? what else is possible?
Yeah, if it says ‘compiling media’ then you have the media library turned on. Go to SETUP >>> SYSTEM >>> MEDIA LIBRARY >>> OFF. That should turn it off and speed up the unit.
Folks are trying to help here and that’s great, but the ball has been dropped. Are you using the rear USB port or the front one on the device?
It is a fact that the rear port does not work correctly and WD can’t fix it by any practical means. The web and this forum is littered with incidents related to the “rear port problem.” Here is one thread:
If you are attempting to use the rear port, it may work for a while but you will definitely encounter freezes, errant ejects, multi hour file transfers, etc. This problem has been reported tons of times over the last year. The problem is big enough to make some new users return multiple devices and then conclude that the thing is just junk and doesn’t work. WD obviously knows this and if they could fix it they would.
I like the WDTVLSMP but I never count on that rear port so I’m only mildly irritated.
