I have a WD TV Media Player model WDAAP0000NBK. I’d like to downgrade my firmware to see if I can solve a problem of files turning into folders. I’m lost to where to find the old firmware files. Can someone please point me in the right direction?
https://support-en.wd.com/app/ansresults/kw/wd%20tv%20firmware%20rollback/page/1
if the firmware version you’re after is not on any of the links … google the firmware you’re after, download the zip, extract and edit the *.ver file (use Notepad) to a higher number than the firmware you’re currently running.
