hello guys, first post from me, have around 2 years enjoying OMV on myWDCloud Gen1. so first: thanks!
now I’m with a problem, a stupid thing I did on long night hours, clean Debian, OMV 3, lost /dev/sda4 yesterday, maybe some wrong type I did and red light is brilliant now.
i connect telnet for recovery and cant’t mount /dev/sda4 … so I’m stuck there.
opened from the case and used usb with not good luck, maybe because my Mac can’t read ext3 or ext4 or something like.
my English is not better, thx from now, any suggestions are welcome.
CamMx
#18 SMP Tue Nov 24 15:10:48 UTC 2015
Use this info for login:
Login: root
Password: mycloud
recovery login: root
Password:
BusyBox v1.23.2 (2015-10-10 12:34:21 UTC) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
~ # cd /dev
/dev # ls
autofs kmem pts ttyS1
bsg kmsg random ttyS2
bus mem rtc0 ttyS3
cachefiles network_latency sda ubi_ctrl
console network_throughput shm urandom
cpu_dma_latency null temp usbdev1.1
full port tty usbdev2.1
fuse ptmx ttyS0 zero
/dev # cd …
/ # mount /dev/sda4 /mnt
mount: mounting /dev/sda4 on /mnt failed: No such file or directory
well, when I was about to surrender debian live, gparted and testdisk give me back my data folder!
partitions was damaged and I could restore 2 of 4 … because data is here I guess will backup 3.6TB to another disk and will try DSM on next week.
anyway, if you think I can restore without risk these 2 partitions (check image) I can try. I’ve got 2 days suffering for my important data.
thanks again
I’ve successfully installed your Clean Debian(Not OMV) on wdmy gen 2 with New HDD.
(WDMyCloud-Gen2/Debian/Dev/Debian-kernel-bin_4.14.4_002.tar.xz)
It seems that my wdmc is working well.
The only problem(or question) is…
I’m not sure if wdmc is sleeping or not when it is definitely not used.
Like your instruction, “/etc/rc.local” includes the following lines.
I guess that LED shoud be Blue when HDD is in standby(or sleep) mode.
Usually LED is steady green. Sometimes when there is a hdd access, it blinks yellow.
Is there any log file to check if wdmc goes into sleep mode? or any method?
I followed the installation instructions and all went smoothly. I have sda1 as swap sda3 as system and sda2 for my data. However when I try to create a shared folder no devices show in the drop down menu. I’ve tried unmounting and mounting sda2 and still no joy, Any help appreciated. I have a 2TB gen 2 mycloud. Thanks
James
SOLVED - deleted the sda2 partition and after recreating I was able to mount within gui and create shares on the sda2 partition. Not sure why it wasn’t working
Installed Debian and OMV without any problem. But after reboot, i got no access to any service. no webinterface, no ssh, no smb. i can ping the device, but not more. testet usb recovery before i installed debian, worked ok, but now, the mycloud ignores my usb recovery stick, boots from HDD (sounds so) and the front light stays yellow. any ideas?
Hi Mr @Fox_exe , so I did install Debian on the MyCloud EX2 Ultra, but after having some issues with the network, I rebooted and yeah… The device doesn’t connect to the network anymore, please tell me that there is a way to save this device!
@HRVSTR, Update kernel to 3.2.68 (On my website / g.drive folder).
Its a SystemD issue (No required modules in kernel, so systemd can’t update).
@rspy24, Extract HDD’s, poweron device. After ~1 min. insert HDD’s back and connect via Telnet.
Do: mdadm -As mount /dev/md1 /mnt/root nano /mnt/root/etc/network/interfaces
Check this config or rewrite to default (Replace MAC address to actual/real):
