I am very much an English speaker.
I have OMV running on my WD My Cloud.
Extract the package you will need the 3 files. I just put them on the Desktop for ease of use.
It was pretty simple.
Remove the Drive from the enclouser.
You need a SATA to USB device.
Connect your drive via device to a linux computer.
What you need to do now is dump the rootfs.img to /dev/sdb1 and /dev/sdb2
This is done with the unix dd command, thought I prefer dc3dd it gives more feedback. Here is an example
dd if=/root/Desktop/rootfs.img of=/dev/sdb1
dd if=/root/Desktop/rootfs.img of=/dev/sdb2
dd if=/root/Desktop/kernel.img of=/dev/sdb5
dd if=/root/Desktop/config.img of=/dev/sdb7 <— this is needed if you are using the OMV version other wise you won’t be able to login.
Then put your drive back together and boot it up. Give it about a minute and you will see a green light.
Then you need to do a few things.
ssh via root@wddriveip
password: mycloud
passwd ← change your password
First change your language:
apt-get install fake-hwclock
dpkg-reconfigure locales
dpkg-reconfigure tzdata
Things should be in a more workable state.
Now just point to you WD Cloud’s IP address and you will load up the Web GUI.
User: admin
Password: mycloud
You may want to change the time in OMV also.
Now, here are the issues I am having and I hope someone can give some insight on this. I am not able to modify the /etc/apt/sources.list the file is write protected unless I am root. But this is very confusing because when I ssh into the drive I am root. I need to change the sources from Russian to English.
