Just install ramlog - sleep mode works fine as is. I posted a script to flash the LED on P36 and just below it is a script (really just a command) to show what files are written in the last x minutes. This will help you identify what the system is writing to and if it’s logs, just redirect them to /var. They will then be managed by ramlog.
First of all, thank you Fox_exe for all the work you have already put into this - you can certainly see it is very much appreciated by the community as it is.
I myself have been waiting for something like this since I discovered the native system of the wdmycloud is pretty much useless to me.
However, to my problem.
I have installed the newer OMV (1.12) image you provided, using the autoinstall script and the run_… script afterward.
OMV runs and I can log on via ssh without any problems.
However, I encounter numerous issues with the ‘locales’ package. I simply can not install it…
root@MyCloud:~# apt-get install locales
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
locales : Depends: glibc-2.13-1
Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
E: Unable to correct problems, you have held broken packages.
Its revert mdraid to normal state (Need for easy change/revert firmware by my Autoinstall script)
About mycloud.local - just edit /etc/hosts and change to what you want (Or just delete “mycloud” and “local”)
What about if I install omv now, do I still need to run those commands or by any chance you updated your script? (sorry but I’m not sure about what they do)
You do not need to disable Samba but you need to ensure it sends its logs to /var, which can then be manged by ramlog.
hdparm -y /dev/sda
to make sure it spins your disk down. If it works, then install ramlog and the script.
Hope this helps.> I test with hdparm -y /dev/sda, my hdd enter standby mode at once, however it wake up a few seconds later, is it normal ?> I have installed ramlog, do i have to modified samba start file and ramlog file ? How to do it ?> Thx
root@MyCloud:~# apt-get install mysql-server
Reading package lists… Done
Reading state information… Done
mysql-server : Depends: mysql-server-5.5 but it is not going to be installed
root@MyCloud:~# apt-get install openmediavault-mysql
openmediavault-mysql : Depends: mysql-server but it is not going to be installed
