Thank you Fox_exe. Еще раз спасибо.
Everything is fine - I also rebooted to check.
Hello!
How to install OwnCloud ?..
After update 1.11 to 1.12 OMV speed of work is slowly… CPU always about 100%, when torrent is worked or copy files by samba
Installed Clean Debian. Then installer latest OMV. Then tried samba3 → samba4 upgrade from fist post.
My device won’t boot now: is see only white indicator lit solid.
Can’t ping, can’t connect via ssh, can’t connect using web ui.
How can I restore my device to ‘Clean Debian’ state without loosing my data?
I need so somehow revert ‘samba3 → samba4’ actions to get a bootable device.
Please help.
I have disassembled the device to get to HDD, but maybe there is another way.
Fox_exe wrote:
Suppose I can connect to MyCloud.
Can you please say what steps should I take to make OMV to skip starting samba service and make SSH accessible?
Just disable samba autoboot: chroot inside rootfs and run update-rc.d samba disable
Also check boot log for errors: cat /var/log/boot | grep error
Fox_exe wrote:
Tried the hard way. Did not receive any DHCP reqests from MyCloud. Is there a way to not to loose the data on my drive, it’s very valueble.
Please help.
Fox_exe wrote:
Thank you for your help! Got it working using HDD recovery from first post.
Now I have only samba4, transmission and webmin running. But I have a problem. I can’t get the right config for samba. Windows asks for login:password even though I’ve setup guest log in. Can you help?
I want my share ‘/data/shares/Public’ to be accessible from Windows 8.1 (WORKGROUP) with certain login:password paid.
Here is my current /etc/samba/smb.conf:
[global]
workgroup = WORKGROUP
dns proxy = no
log file = /var/log/samba/log.%m
max log size = 50
syslog only = no
syslog = 0
debug level = 0
printcap name = /dev/null
getwd cache = yes
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
server role = standalone server
security = share
guest account = nobody
########## Domains ###########
############ Misc ############
load printers = no
printable = no
main protocol=NT1
max protocol = SMB2
######## Optimization ########
read raw = no
write raw = no
max xmit = 262144
read prediction = yes
min receivefile size = 16384
use sendfile = true
#aio read size = 262144
#aio write size = 262144
aio write behind = true
write cache size=2097152
read size=65536
allocation roundup size = 104857600
strict allocate = Yes
strict sync = no
use sendfile = true
socket options = TCP_NODELAY IPTOS_LOWDELAY TCP_NODELAY SO_RCVBUF=2048000
SO_SNDBUF=2048000
#======================= Share Definitions =======================
[public]
path = /data/shares/Public
writable = yes
public = yes
guest ok = yes
guest only = yes
browsable = yes
P.S. Помоги пожалуйста настроить самбу:)
Hi hujanita,
Could you please make more clear on item 0) and 1)
I have the same issue that I can’t start the ramlog service.
Here is example:
Dont forget - Windows not allow multi-user logins. If you already login to NAS as Guest - you cant login in private share (Because Windows already login as Guest)
[global]
security = user
passdb backend = tdbsam
unix password sync = yes
pam password change = yes
map to guest = bad user
use sendfile = true
force group = users[Public]
comment = Public share
browseable = yes
path = /data/Public
guest ok = yes
read only = no
create mask = 0777
force user = root[Private]
comment = Allow only users from Users group
browseable = yes
path = /data/Private
guest ok = no
write list = @users
create mask = 0655
directory mask = 0766
About HDD spindown (Standby mode):
http://info4admins.com/tips-to-spindown-your-hard-disk-in-debian-or-ubuntu/
Need modify samba start script and tuning ramlog:
### BEGIN INIT INFO
# Provides: ramlog
# X-Start-Before: minidlna apache2 samba
# X-Stop-After: minidlna apache2 samba
# Required-Start:
# Should-Start: $local_fs
Then - run:
update-rc.d ramlog remove
update-rc.d ramlog defaults
Quick and dirty sleep indicator to flash the LED when the drive is spun down.
Put the following file /usr/local/bin. Call it dsksts.sh
#!/bin/bash# Script to flash disk led when in standbyflash() { for c in {1..30}; do echo off > /sys/class/leds/system_led/color; sleep 1; echo green > /sys/class/leds/system_led/color; sleep 1; done; }steady() { echo green > /sys/class/leds/system_led/color; sleep 60; }hdparm -S 242 /dev/sda >/dev/null 2>&1while :dostate="$(hdparm -C /dev/sda|grep state|awk '{print $4}')"[["$state" == "active/idle"]] && steady[["$state" == "standby"]] && flashdone
Make it executable with
chmod u+x /usr/local/bin/dsksts.sh
To make it run at boot, edit /etc/rc.local and add
on the line immediately before the line which says
exit 0
So at the end it reads
exit 0
Reboot.
Test it with
hdparm -y /dev/sda
Considerations:
Tested and working only on WD Red drive (model WDC WD20EFRX). Some drives spin up when you check their status.
Set the spin down time with hdparm -S xxx. On my drive
sets it to 1 hour. If I set it to anything less than 15 minutes on my drive it always spins down after 15 minutes (of inactivity).
3. The script runs once a minute so there will be a lag of up to a minute in the LED reflecting the drive’s true state.
EDITED 28 FEB 2015. Reason: I realised we can do this more easily with functions, and also the practice of putting executables in /var is really bad practice. Also, we need only one script now.
If you want to know what files have been written to in the last x minutes (and may be responsible for stopping your disk from spinning down), run the following script (I called it recent.sh and put it in /usr/local/bin/).
#!/bin/bash
[[-z "$1"]] && { echo -e "Finds recently modified files.\nUseage: \"recent X\" where X is minutes.";exit 1; }
now=$(date +'%H:%M')
echo "Files modified in the $1 minutes up to $now:"
find /bin /dev /etc /home /lib /media /mnt /opt /root /sbin /srv /tmp /usr /var -cmin -$1
For example:
recent.sh 5
produces something like this:
Files modified in the 5 minutes up to 16:47:
/root
/root/.viminfo
/usr/local/bin
/usr/local/bin/recent.sh
I try to use the OMV1.12, but i had errors with locales.
I try to run dpkg-reconfigure locales but i had errors
I try to do an apt-get install -f reinstall locales
but still not work, an error with glibc.
So i’m trying OMV 1.11
But i failed to mount my HD:
Failed to mount '/media/e0fcf183-81a7-49b0-88b8-c898f6a6144d/Data/': [mntent]: line 10 in /etc/fstab is bad mount: can't find /export/Data in /etc/fstab or /etc/mtab |
Thanks for your hard work
Regards
Yes. 1.12 brocken (I forgot remove my stuff)
Possible way to fix it - replace HDD UUID in /etc/openmediavault/config.xml
Run “blkid” and see what UUID have your /dev/sda4.
Also change all /Data/ to /Public/
Thanks for your fast reply.
Do you thinks i should wait for a corrected 1.12?
I’m looking for the way to fix 1.11 you told me.
Just to let you know, the error i have the same error in 1.11 than in 1.12 when a try an omv-upadte:
Since release 198, udev requires support for the following features in
the running kernel:
Please upgrade your kernel before or while upgrading udev.
wd_pnn wrote:
Hi hujanita,
Hi wd_pnn,
debian is using dependecy startup sequence for services.
you need to find out which service is started first and add ramlog dependency into the service init.d script.
Unfortunatelly, I do not remember exact steps but following link might also help you to see the service boot order:
For the service dependency definition refer to LSB tags which are part of service init script and looks as follows:
/etc/init.d/xxxx
#!/bin/sh
# Required-Start: ramlog
Hope this will help you.
There might be definitelly better way to do this but those did not work for me.
As for noatime, just add it into etc/fstab noatime into options for ext3 and ext4 partition
Regards,
I just try to restart from the beginning with omv 1.11
When i launch install.sh i have this error:
Creating new partition…
mdadm: set device faulty failed for /dev/sda1: No such device
mdadm: hot remove failed for /dev/sda1: No such device or address
mdadm: Cannot find /dev/md0: No such file or directory
Something wrong: /dev/md0 not exist! Exit now…
Current md’s status:
Personalities : [linear] [raid0] [raid1] [raid10]
md0 : active raid1 sda1[0]
1999808 blocks [2/1] [U\_]
md1 : active raid1 sda2[1]
1999808 blocks [2/1] [_U]
unused devices:
Edit: a reboot make it work
Thanks to Fox_exe’s great job.
I have installed the OMV. I can use almost every function that original WD FW has.
However, I have met some problems
The ip address is correct because I use it to login ssh successfully.
How to install php5 and mysql, I run mysql in Web Gui without success.
What should be inside /etc/apt/sources.list
My content is follow:
deb http://ftp.us.debian.org/debian stable main contrib non-free
deb http://ftp.debian.org/debian/ wheezy-updates main contrib non-free
deb http://ftp.debian.org/debian/ wheezy-backports main
deb http://security.debian.org/ wheezy/updates main contrib non-free
Should I add more ?
Thanks you very much.
duncan2015 wrote:
- I can login to Web GUI by http://mycloud.local/
- How to install php5 and mysql, I run mysql in Web Gui without success.
- What should be inside /etc/apt/sources.list
- How to enter sleep mode ?
