That’s working!!!
Where are tje binary for btsync? Or do I have to do something with apt-get?
http://www.getsync.com/intl/ru/download (Linux → arm)
http://download.getsyncapp.com/endpoint/btsync/os/linux-arm/track/stable
Do you know how to change led color, my wife prefer blue
/etc/init.d/wd-leds.sh
Hello again,
i have made some tweaks on my smb.conf and thats the result
Only the upload speed is not the best, but maybe someone will figure out, how to increase this.
I recognized the best speed increase with: read size=65536
My smb.conf
[global]
log file = /var/log/samba/log.%m
read raw = no
write raw = no
server role = standalone server
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccess$
max xmit = 262144
read prediction = yes
workgroup = WORKGROUP
debug level = 0
printcap name = /dev/null
syslog = 0
getwd cache = yes
min receivefile size = 16384
use sendfile = true
#aio read size = 262144
#aio write size = 262144
aio write behind = true
write cache size=2097152
read size=65536
allocation roundup size = 104857600
strict allocate = Yes
strict sync = no
use sendfile = true
security=user
lanman auth=no
main protocol=NT1
encrypt passwords=true
client ntlmv2 auth=yes
wide links=yes
state cache=yes
large readwrite=yes
oplock contention limit=5
oplock break wait time=100
load printers = no
printable = no
max log size = 50
deadtime = 30
enable core files = no
create mask = 0775
force create mode = 0775
directory mask = 0775
force directory mode = 0775
local master = yes
domain master = no
preferred master = auto
os level = 5
dns proxy = no
idmap uid = 10000-65000
idmap gid = 10000-65000
force group = users
unix extensions = no
acl check permissions = false
max protocol = SMB2
browseable = yes
syslog = 1
socket options = TCP_NODELAY IPTOS_LOWDELAY TCP_NODELAY SO_RCVBUF=2048000 SO_SNDBUF=2048000
smb encrypt = disabled
writeable = yes
delete veto files = true
Thanks!
Hi Fox_exe,
i tried to upgrade to jessie release using these steps:
- i have restored sda1 and sda2 content with your clean debian wheezy image
- updated locales and tzdata
- run the apt-get update & apt-get upgrade on wheezy
- reboot
- in /etc/apt/sources.list Ihave changed the repos to jessie
- apt-get update & apt-get distro-upgrade
upgrade to jessie has failed because of kernel capabilities (i do not recall exact list of missing features).
So i took latest kernel from you in following steps:
- i have restored sda1 and sda2 content with your debian wheezy image
- updated kernel with dd command following your guide
- reboot
- reboot
Upgrade to jessie suceeded, however after second reboot the wd mycloud did not start. I am not sure whether i made something wrong. However, if i did not perhaps it is worth to mention that currently it is not possible to upgrade to jessie perhaps directly within this post::
Yes, you can upgrade to Jessie or “Sid” - All works fine…
Ok, i retest it and prepare img for easy upgrade.
Thanks for your work Fox_exe.
Did someone resolve the usb performance problem ?
when I copy file from my USB3 device to the MyCloud device, i’ve got only 6Mo/s read and write speed.
The same USB3 device connect to Windows write speed is 50Mo/s.
The kernel support USB 3.0 ?
apt-get install ntfs-3g
mkdir /mnt/usb (Its my samba /shares/ folder)
mount -t auto /dev/sdb1 /mnt/usb
dd if=/mnt/usb/videofile.avi of=/data/Video/videofile.avi bs=4M
371+1 записей считано
371+1 записей написано
скопировано 1557147648 байт (1,6 GB), 68,6467 c, 22,7 MB/c
* /data - is my /dev/sda4 mountpoint (Clean debian)
* USB 2.0 external box for 2.5" HDD / Samsung 250GB
* Samba speed - 30-35MB/s
Tanks I try the same command (copy movie with dd bs=4M) and I have the same result on my USB 3 device (21mo/s). (better than my original 6Mo/s)
I dont know what is the result with original firmware but It’s still low for usb 3.0. I think it’s USB 2 limited.
Im trying to developemnt (Wt) Application for the Box, but im stucking now with the cross compiler toolchain.
Is it important to know which gcc version was used to build the kernel, and if so can you tell me?
I tried to install gcc 4.9 from jessie but failed.
Maybe you know a good tutorial or have one?
Thank you
http://support.wdc.com/product/download.asp?groupid=904&sid=233
Download it.
Inside - patches for binutils, chroot (wheezy/jessie) and buildscripts for all of this.
hello
I currently have Clean debian installed, can i use Autoinstall script to restore original firmeware ? or should I use replace HDD procedure?
I found in your backup folder an old firmware who seem to be in good format (not .deb), but your script autoinstall take 2 config file and the zip contains 1. I miss someting ?
Thanks for help.
Hello
How can I reinstall Clean Debian image? Now MyCloud is running OpenMediaVault image. I cannot run install script, I receive: “sudo: unable to execute ./Install.sh: Permission denied”, even after
chmod +x install.sh
Yeah, OMV mount “Data volume” with “noexec” parameter.
mount -o remount,exec /data
Where /data - you mount point for /dev/sda4.
floyk wrote:
hello
Dont use config from backup. Only rootfs and kernel + autoinstall.zip
Thank you Fox_exe, Debian on the wdmycloud works great for me and opens new possibilities.
I am trying on setting up FHEM ( http://fhem.de/fhem.html)) on the mycloud and could get everything running except the so called CUL device, which would require a cdc_acm usb driver , which seems to be not installed. Do you have any idea how to get such a driver?
thx very much. but i cant change the system language. when i try to change i will get only ru_ru.utf 8. help me pls
apt-get updateapt-get install locales
Или, если уже установлен:
dpkg-reconfigure locales
