I would like to use two Home Duo storages and sync each other. Is it possible ?
You can sync content from a Windows or macOS / OS X system with the Desktop Sync feature. But synchronization between two WD My Cloud Homes is not supported.
If you have a spare PC, then itβs possible.
You can set it up to automatically mirror the 1st My Cloud Home to the 2nd one using a program called Cobian backup. You can also use Task Scheduler to make the computer automatically switch to sleep mode after the backup is finished/wake up before the backup.
I have set up one of my laptops to automatically sync the My Cloud Home onto a different HDD, and it does work quite well.
