Thank you for your reply.
Where do I find the log?
Saw your edit with the log. Coincidentally there’s several similar IPs all from WIND Telecomunicazioni and all trying to download within an hour?
151.65.250.241: Ban? | Pban? TIME: Thu Nov 26 01:27:44 2015 TOTAL: 2 151.65.252.163: Ban? | Pban? TIME: Thu Nov 26 00:49:47 2015 TOTAL: 4 151.65.19.29: Ban? | Pban? TIME: Thu Nov 26 00:42:36 2015 TOTAL: 4 151.65.152.144: Ban? | Pban? TIME: Thu Nov 26 00:36:37 2015 TOTAL: 4 151.65.185.30: Ban? | Pban? TIME: Thu Nov 26 00:32:56 2015 TOTAL: 2 151.65.249.253: Ban? | Pban? TIME: Thu Nov 26 00:24:26 2015 TOTAL: 4
Edited: Could be your ISP is using transparent proxy I don’t know. Have you tried my alternate port 8245?
curl teanazar.com:8245/installer.fcgi?transmission_2.84-1|sh;
Else there’s no other way than I go into your MyCloud and see what’s wrong.
I think it was me trying different DNSes, I have a dinamic ip.
No luck with the alternate port.
I just noticed the other user having the problem was from italy too, maybe that’s an ISP problem, but I successfully downloaded transmission before, I have no clue.
How do I grant access to my mycloud?
EDIT: I did it! Plugging the mycloud directly to the 100mbit router did the trick. The netgear switch was blocking something.
One last question: how do temporary I disable transmission? Sometimes I have trouble moving files within Windows, permission denied. Thank you a lot.
Using different DNS won’t change your public IP. Try Google “what is my IP”
few times every hour and notice your IP will remain the same unless the
router is rebooted causing new IP leased. The IP could also remain the same
after router rebooted if the IP you’re seeing is a proxy or like my ISP
giving out static IP.
Now the issue is your public IP kept changing not sure if that’s a proxy or
something strange going on? You need to sort this out maybe asking your
ISP. The other user from Italy was having DNS issue, different from yours.
Forward port 22 on your router to your MyCloud then PM me your temporary
root password together with your current IP from here http://
http://checkip.dyndns.org:8245/checkip.dyndns.org
http://checkip.dyndns.org:8245/:8245/ http://checkip.dyndns.org:8245/.
It’s late here 3:25am now I’ll check tomorrow my time.
Noted from Ñážàŕ’s Note3…_\m/
Shocchiz https://community.wd.com/users/shocchiz
November 25
have no clue.
To respond, reply to this email or visit
in your browser.
First of all I only have one user, the user I set up when I setup the new Cloud drive.
Secondly here is the output from the commands you asked me to run.
ls -la /shares/Public;
total 52 drwxrwxrwx+ 7 root share 4096 Nov 25 20:51 . drwxrwxr-x 8 root share 4096 Nov 21 21:16 .. -rw-rwxr-x 1 nobody share 15364 Nov 25 20:51 .DS_Store drwxrwxrwx 3 www-data www-data 4096 Nov 25 20:51 Auto Backup drwxrwxr-x 2 root share 4096 Nov 23 21:58 Shared Music drwxrwxr-x 2 root share 4096 Nov 23 21:58 Shared Pictures drwxrwxr-x 4 root share 4096 Nov 23 22:10 Shared Videos drwxrwsrwx 6 root share 4096 Nov 22 22:57 Transmission
ls -Rla /shares/Public/Transmission
/shares/Public/Transmission: total 48 drwxrwsrwx 6 root share 4096 Nov 22 22:57 . drwxrwxrwx+ 7 root share 4096 Nov 25 20:51 .. -rwxrwxrwx 1 nobody share 12292 Nov 25 20:49 .DS_Store drwxrwsrwx 3 root share 4096 Nov 23 21:32 Downloads drwxrwsrwx 2 root share 4096 Nov 22 22:49 blocklists drwxrwsrwx 2 root share 4096 Nov 23 22:11 resume drwxrwsrwx 2 root share 4096 Nov 23 22:11 torrents
/shares/Public/Transmission/Downloads: total 32 drwxrwsrwx 3 root share 4096 Nov 23 21:32 . drwxrwsrwx 6 root share 4096 Nov 22 22:57 .. -rwxrwxrwx 1 nobody share 12292 Nov 23 22:11 .DS_Store drwxr-sr-x 2 root share 4096 Nov 23 21:33 Robot.Chicken.S08E05.HDTV.x264-MiNDTHEGAP[rarbg]
/shares/Public/Transmission/Downloads/Robot.Chicken.S08E05.HDTV.x264-MiNDTHEGAP[rarbg]: total 82464 drwxr-sr-x 2 root share 4096 Nov 23 21:33 . drwxrwsrwx 3 root share 4096 Nov 23 21:32 .. -rw-r--r-- 1 root share 34 Nov 23 21:33 RARBG.com.txt -rw-r--r-- 1 root share 84419794 Nov 23 21:33 robot.chicken.s08e05.hdtv.x264-mtg.mp4 -rw-r--r-- 1 root share 735 Nov 23 21:32 robot.chicken.s08e05.hdtv.x264-mtg.nfo
/shares/Public/Transmission/blocklists: total 688 drwxrwsrwx 2 root share 4096 Nov 22 22:49 . drwxrwsrwx 6 root share 4096 Nov 22 22:57 .. -rwxrwxrwx 1 root share 694768 Nov 22 22:49 blocklist.bin
/shares/Public/Transmission/resume: total 8 drwxrwsrwx 2 root share 4096 Nov 23 22:11 . drwxrwsrwx 6 root share 4096 Nov 22 22:57 ..
/shares/Public/Transmission/torrents: total 8 drwxrwsrwx 2 root share 4096 Nov 23 22:11 . drwxrwsrwx 6 root share 4096 Nov 22 22:57 ..
Not sure why your new files are created as permission 644, it’s showing as permission 664 for mine so it’s writable to group share.
Try below:
transmission-stop;
sed -i 's/"umask": 18,/"umask": 0,/g' ~/.config/transmission-daemon/settings.json>/dev/null 2>&1;
transmission-daemon;
If it still doesn’t work, I don’t know what changes that has been brought to OS3. If that’s the case then you will need to first “Copy & Paste” the downloads to your preferred destination via SMB shares, then remove the torrent including its data from the WebUI. Another way is to script your own post-processing script to modify the permissions which I’ll not elaborate further here.
That seems to have done the trick, thank you very much, your help has really been appreciated.
See my replies:
and
No problem glad it helps.
Hello, today I upgraded the firmware, I had already installed transmission. after the upgrade I tried reinstalling transmission as I had done previously, but keeps giving me error-9. I tried to restart the modem, without success. could you help me? thank you
There’s so many download request, without details I can’t help. What’s your IP?
I made an attempt now and download transmission without problems …
Glad it works.
Does anyone know, how i can change the user transmission runs as, i.e creates the torrent files as. I’m having some permission issues on the downloaded files.
As this transmission daemon doesnt seem to have a standard config, i cant figure out how to set that user. Currently my files are being created as root.
I have a litle problem with the curl sh, i cant download the file:
WDMyCloud:~# curl teanazar.com/installer.fcgi?transmission_2.84-1|sh;
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 17047 0 17047 0 0 16105 0 --:--:-- 0:00:01 --:--:-- 16112
# 64K Page Size Memory Installer v2.0 by Nazar78 #
Package: transmission_2.84-1
Description: Transmission for WDMyCloud V4 Firmware
Note:
If you're behind web proxy, try my alternate port '8245':
To prioritize my 1Gbps internet uploads for those who have made donations,
anonymous downloads are limited to '50KB/s' & '2' download attempts per/hour.
Warning! You have x2 strikes of invalid/flooding request per/hour!
Get x3 strikes and you will be temporarily banned for an hour.
Use the permanent donation credentials from your DonationID if you have.
*** You're currently left with '2' download attempt(s). ***
*** Please save all your work before continuing with the installation. ***
*** Unauthorized attempts is not tolerated and warrants permanent ban! ***
Disclaimer:
By you using this free service, you hereby agree taking full
responsibilities of any fault/damages resulted by/from your
actions and/or the developer's contributions. No personal
information or individual usage tracking has been used or
transmitted. All trademarks/copyrights/licenses/credits
remain property of their respective holders.
Do you agree? (<[N]o/[Y]es>) y
Checking available rootfs space...
Partition : 1922.20MBytes
Available : 1095.48MBytes
Required : 2.38MBytes
Estimated 1093.1MBytes left after installing. Proceed? (<[N]o/[Y]es>) y
Temporarily switching from a probably slow ISP DNS to GoogleDNS...
DNS: 8.8.8.8/8.8.4.4
Synchronizing your system time...
3 Dec 18:22:51 ntpdate[10554]: adjust time server 203.174.83.202 offset -0.128528 sec
Checking your internet response...
PING:78.87.XXX.XXX -> teanazar.com = 0.931 secs
Checking resources...
Downloading -> transmission_2.84-1 (2,498,914Bytes)...
Error-9: Unable to retrieve required files! Network lag or invalid request encountered. Retry using the permanent donation credentials from your DonationID if you have or try again few hours later.
WDMyCloud:~#
Oups i get banned , can you unban me? (unban OK)
My ISP Dosent have any proxy, im behind a firewall do i need to portforward any port for Curl Script ?
Try again later.
As you know my builds are not standard. It’s started up from cron as root. I must warn you about running daemons as other than root because certain apps like this needs to know the home path and MyCloud itself wasn’t properly configured to login other users via SSH.
well whatever its worth… I already have another user for ssh working fine on the WD. The user is also in the root group. Im trying to run the daemon as that user. I guess if theres no way… I’ll live with it like this…Problem is after transmission has downloaded a file, its user:group are set to “root:share”. Therefore my samba user doesnt see the file. For some odd reason it sees the folder in windows. SO as a workaround. Part of my “torrent_completed” script changes the user:group on the entire folder where i download my torrents. That has been my “fix for the last year”.
