**WD I do understand that I have voided my warranty**
Hi there,
I have recently purchased a WD My Cloud 2TB. I removed the 2TB HDD and installed it in my Digital Video Recorder. Beings that I had a spare 1TB HDD, I thought I could install it in the enclosure and it would work pretty much straight away…which later on I realised, I was so wrong.
So far I have spent 4 long nights trying to get it working, I have followed tutorials multiple times, to get it back up and running, but unfortunately had no luck. Could some WD guru out there help??
These are the tutorials I followed which haven’t solved my issue;
- Fox_exe tutorial → http://community.wd.com/t5/WD-My-Cloud/HDD-Replacement-Single-Drive/m-p/786229#M20429
This tutorial I have followed numerous of times, infact I have done it that many times, I can recite the shell commands (which is a good thing I suppose). My end result? Solid red light.
- DJH816 tutorial http://community.wd.com/t5/WD-My-Cloud/GUIDE-Debrick-a-completely-dead-MyCloud/m-p/704480/highlight/true#M10660
This tutorial I used the 2TB Virgin img, which I carried out 3 times, just incase I had done something wrong. The end result? Solid white light. I actually thought I was getting somewhere when I saw a solid white light, but then learnt there was another underlying issue. Please note, I left the device on for a good 8 hours + just incase it had to install the OS or any files needed.
Here is what HDD partition table looks like
Could someone please shed some light as to where I am going wrong?
Thanks in advance,
Fernando
