Hi again!
I got myself an FTDI cable. Solved my problems regarding data corruption. I now have some legible output when I boot (this log without drives connected). Are you ready to get started? This is the MCM Gen2.
BootROM - 1.73
Booting from NAND flash
General initialization - Version: 1.0.0
Detected Device ID 6820
High speed PHY - Version: 2.0
Load WD GrandTeton Serdes Config:
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 06 | SATA0 |
| 1 | 05 | PCIe0 |
| 2 | 06 | SATA1 |
| 3 | 05 | USB3 HOST1 |
| 4 | 05 | USB3 HOST0 |
| 5 | 00 | SGMII2 |
PCIe, Idx 0: detected no link
High speed PHY - Ended Successfully
DDR3 Training Sequence - Ver TIP-1.26.0
mvSysEnvGetTopologyUpdateInfo: TWSI Read failed
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
__ __ _ _
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01_v1.04 (Aug 20 2015 - 11:11:05) Marvell version: 2014_T3.0p6
mvBoardIdIndexGet(boardId) = 1
Board: GrandTeton DB6820
SoC: MV88F6820 Rev A0
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1332 [MHz]
L2 @ 666 [MHz]
TClock @ 200 [MHz]
DDR @ 666 [MHz]
DDR 32 Bit Width, FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 512 MiB
Map: Code: 0x1fece000:0x1ff95bd4
BSS: 0x1ffef254
Stack: 0x1f9cdf20
Heap: 0x1f9ce000:0x1fece000
raise: Signal # 8 caught
U-Boot Environment: 0x00000000:0x00080000 (NAND)
NAND: ID: daad ,256 MiB
MMC: mv_sdh: 0
PCI-e 0: Detected No Link.
USB2.0 0: Host Mode
USB3.0 0: Host Mode
USB3.0 1: Host Mode
Board configuration detected:
Creating 1 MTD partitions on "nand0":
0x00000f500000-0x00000ff00000 : "mtd=7"
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=7"
UBI: MTD device size: 10 MiB
UBI: number of good PEBs: 80
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 32
UBI: total number of reserved PEBs: 48
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 2/0
UBIFS: mounted UBI device 0, volume 0, name "reserve2"
UBIFS: mounted read-only
UBIFS: file system size: 4063232 bytes (3968 KiB, 3 MiB, 32 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 200807 bytes (196 KiB)
Loading file '/mac_addr' to addr 0x02000000 with size 18 (0x00000012)...
Done
Set lan 2 WakeOnLan ok
Enable HD1
Enable HD2
Net:
| port | Interface | PHY address |
| egiga0 | RGMII | In-Band |
| egiga1 | RGMII | In-Band |
| egiga2 | SGMII | 0x00 |
egiga0, egiga1, egiga2 [PRIME]
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x500000, size 0x500000
5242880 bytes read: OK
NAND read: device 0 offset 0xa00000, size 0x500000
## Booting image at 00a00000 ...
## Booting kernel from Legacy Image at 00a00000 ...
Image Name: Linux-382
Created: 2016-04-29 2:03:10 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4093236 Bytes = 3.9 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 00f00000 ...
Image Name: Ramdisk
Created: 2016-06-29 9:41:05 UTC
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 2221563 Bytes = 2.1 MiB
Load Address: 00e00000
Entry Point: 00e00000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.10.39 (kman@kmachine) (gcc version 4.6.4 (Linaro GCC branch-4.6.4. Marvell GCC Dev 201310-2126.3d181f66 64K MAXPAGESIZE ALIGN) ) #1 SMP Fri Apr 29 10:03:05 CST 2016 2014T30p5 Build-git11369fb
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: Marvell Armada 380/381/382/385/388 (Device Tree), model: Marvell Armada 385 Development Board
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 1 pages/cpu @c0930000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16364
Kernel command line: root=/dev/ram console=ttyS0,115200
PID hash table entries: 2048 (order: -2, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 3, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 2, 131072 bytes)
allocated 131072 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 512MB = 512MB total
Memory: 511808k/511808k available, 12480k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff8000 ( 32 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xfff00000 ( 503 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0714270 (7217 kB)
.init : 0xc0718000 - 0xc075a080 ( 265 kB)
.data : 0xc075c000 - 0xc07a7e40 ( 304 kB)
.bss : 0xc07a7e40 - 0xc0871570 ( 806 kB)
Hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:16 nr_irqs:16 16
LSP version: linux-3.10.39-2014_T3.0p5
sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 171798ms
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410054c9, AUX_CTRL 0x16070000, Cache size: 1048576 B
Console: colour dummy device 80x30
Calibrating delay loop... 2655.84 BogoMIPS (lpj=13279232)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 4096
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0xc056c210 - 0xc056c268
mvebu-pmsu: Initializing Power Management Service Unit
Initializing CPU Reset module
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (5311.69 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
xor: measuring software checksum speed
arm4regs : 1420.800 MB/sec
8regs : 940.800 MB/sec
32regs : 918.400 MB/sec
xor: using function: arm4regs (1420.800 MB/sec)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
irq: Cannot allocate irq_descs @ IRQ196, assuming pre-allocated
irq: Cannot allocate irq_descs @ IRQ228, assuming pre-allocated
bio: create slab <bio-0> at 0
raid6: int32x1 355 MB/s
raid6: int32x2 347 MB/s
raid6: int32x4 446 MB/s
raid6: int32x8 384 MB/s
raid6: using algorithm int32x4 (446 MB/s)
raid6: using intx1 recovery algorithm
mvebu-pcie pcie-controller.3: PCIe0.0: link down
mvebu-pcie pcie-controller.3: PCIe1.0: link down
mvebu-pcie pcie-controller.3: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe8000000]
pci_bus 0000:00: root bus resource [bus 00-ff]
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI: bus1: Fast back to back transfers enabled
PCI: bus2: Fast back to back transfers enabled
pci 0000:00:01.0: PCI bridge to [bus 01]
pci 0000:00:02.0: PCI bridge to [bus 02]
PCI: enabling device 0000:00:01.0 (0140 -> 0143)
PCI: enabling device 0000:00:02.0 (0140 -> 0143)
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Switching to clocksource armada_370_xp_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 0, 32768 bytes)
TCP bind hash table entries: 4096 (order: 0, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 1024 (order: 0, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 0, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 2112K (c0f08000 - c1118000)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 8192 (order 0, 32768 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
fuse init (API version 7.22)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 1002
async_tx: api initialized (async)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
mv_xor f1060800.xor: Marvell shared XOR driver
mv_xor f1060800.xor: Marvell XOR: ( xor cpy intr )
mv_xor f1060800.xor: freeing 1 in use descriptors!
mv_xor f1060800.xor: Marvell XOR: ( crc32c )
mv_xor f1060900.xor: Marvell shared XOR driver
mv_xor f1060900.xor: Marvell XOR: ( xor cpy intr )
mv_xor f1060900.xor: freeing 1 in use descriptors!
mv_xor f1060900.xor: Marvell XOR: ( crc32c )
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 44) is a 16550A
console [ttyS0] enabled
f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 45) is a 16550A
brd: module loaded
loop: module loaded
ahci_mv f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci_mv f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
scsi0 : ahci_mv_platform
scsi1 : ahci_mv_platform
ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 58
ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 58
armada-nand f10d0000.nand: Initialize HAL based NFC in 8bit mode with DMA Disabled using BCH 4bit ECC
Nand Flash Timing = [WP : 12], [WH : 10]
NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix NAND 256MiB 3,3V 8-bit), 256MiB, page size: 2048, OOB size: 64
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
8 ofpart partitions found on MTD device armada-nand
Creating 8 MTD partitions on "armada-nand":
0x000000000000-0x000000500000 : "U-Boot"
0x000000500000-0x000000a00000 : "uImage"
0x000000a00000-0x000000f00000 : "uRamdisk"
0x000000f00000-0x00000c800000 : "image.cfs"
0x00000c800000-0x00000d700000 : "rescue fw"
0x00000d700000-0x00000eb00000 : "config"
0x00000eb00000-0x00000f500000 : "reserve1"
0x00000f500000-0x00000ff00000 : "reserve2"
SoC: model = 0x6820, revision = 0x4
mvPncVirtBase = 0xe0e00000, pncTcamSize = 1024
o 3 Giga ports supported
o SKB recycle supported (Disabled)
o NETA acceleration mode 4
o BM supported for CPU: 4 BM pools
o PnC supported (Enabled)
o RX Queue support: 8 Queues * 256 Descriptors
o TX Queue support: 8 Queues * 532 Descriptors
o GSO supported
o GRO supported
o Receive checksum offload supported
o Transmit checksum offload supported
o Driver ERROR statistics enabled
o Driver INFO statistics enabled
o Driver DEBUG statistics enabled
port #0: is_sgmii=0, is_rgmii=1, phy_addr=2
o Loading network interface(s) for port #0: cpu_mask=0x3, tx_csum_limit=9800
o Port 0 is connected to Linux netdevice
o egiga0, ifindex = 2, GbE port = 0
giga p=0: mtu=1500, mac=00:50:43:02:02:01 (platform)
port #1: is_sgmii=0, is_rgmii=1, phy_addr=1
o Loading network interface(s) for port #1: cpu_mask=0x3, tx_csum_limit=2048
o Port 1 is connected to Linux netdevice
o egiga1, ifindex = 3, GbE port = 1
giga p=1: mtu=1500, mac=00:50:43:02:02:02 (platform)
port #2: is_sgmii=1, is_rgmii=0, phy_addr=0
o Loading network interface(s) for port #2: cpu_mask=0x3, tx_csum_limit=2048
o Port 2 is connected to Linux netdevice
o egiga2, ifindex = 4, GbE port = 2
giga p=2: mtu=1500, mac=00:50:43:02:02:03 (platform)
libphy: orion_mdio_bus: probed
mdio_bus f1072004.mdio-mi: cannot get PHY at address 2
mdio_bus f1072004.mdio-mi: cannot get PHY at address 1
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-orion: EHCI orion driver
orion-ehci f1058000.usb: EHCI Host Controller
orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
orion-ehci f1058000.usb: irq 50, io mem 0xf1058000
orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
xhci-hcd f10f0000.usb3: xHCI Host Controller
xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
xhci-hcd f10f0000.usb3: irq 48, io mem 0xf10f0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
xhci-hcd f10f8000.usb3: xHCI Host Controller
xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
xhci-hcd f10f8000.usb3: irq 49, io mem 0xf10f8000
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mvebu-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
i2c /dev entries driver
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
md: raid10 personality registered for level 10
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
dm_crypt using the OCF package.
cpuidle: using governor ladder
armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources: Total CESA HW channels supported 2
armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources: CESA feature: chain(0)
mvCesaInit: channels=2, session=640, queue=256
armada-cesa-ocf f109d000.crypto: cesa_ocf_probe: CESA driver operate in ocf(0) mode
cesadev_init(c0734f0c)
TCP: cubic registered
NET: Registered protocol family 17
8021q: 802.1Q VLAN Support v1.8
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
registered taskstats version 1
mvebu-rtc f10a3800.rtc: setting system clock to 2016-09-24 23:37:07 UTC (1474760227)
md: Waiting for all devices to be available before autodetect
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: Scanned 0 and added 0 devices.
md: autorun ...
md: ... autorun DONE.
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) readonly on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 256K (c0718000 - c0758000)
init started: BusyBox v1.20.2 (2014-10-30 15:28:59 CST)
starting pid 1255, tty '': '/etc/rc.sh'
** Mounting /etc/fstab
umount: can't umount /proc: Invalid argument
umount: can't umount /usr/local/modules: Invalid argument
offset_flag=1,vaule_flag=1,bit_flag=0
offset_flag=1,vaulUBI: attaching mtd5 to ubi0
e_flag=1,bit_flag=0
UBI: scanning is finished
UBI: attached mtd5 (name "config", size 20 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 160, bad PEBs: 0, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 139542954
UBI: available PEBs: 22, total reserved PEBs: 138, PEBs reserved for bad PEB handling: 10
UBI: background thread "ubi_bgt0d" started, PID 1273
UBI device number 0, total 160 LEBs (20316160 bytes, 19.4 MiB), available 22 LEBs (2793472 bytes, 2.7 MiB), LEB size 126976 bytes (124.0 KiB)
UBIFS: background thread "ubifs_bgt0_0" started, PID 1278
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "config"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 14475264 bytes (13 MiB, 114 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS: reserved for root: 683702 bytes (667 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 45518461-8BB3-4038-B549-232AB55DABE5, small LPT model
umount: can't umount /usr/local/tmp/image.cfs: No such file or directory
rm: can't remove '/usr/local/tmp/image.cfs': No such file or directory
umount: can't umount /usr/local/tmp: Invalid argument
first good block is 0
image len = 109924352 , image checksum = aa3e2e34
dump image checksum=aa3e2e34
mount cmd:busybox mount -t squashfs -o loop /usr/local/tmp/image.cfs /usr/local/modules
cp: can't stat '/tmp1/*': No such file or directory
ln: /usr/sbin/./transmission-daemon: File exists
ln: /usr/sbin/./transmission-remote: File exists
ln: /lib/./liblber-2.4.so.2.5.6: File exists
ln: /lib/./libminiupnpc.so: File exists
ln: /lib/./libnatpmp.so: File exists
ln: /lib/./libpam.so.0.81.6: File exists
ln: /usr/local/sbin/alert_email_config.sh: File exists
ln: /usr/sbin/language.sh: File exists
dev.raid.speed_limit_max = 1000
egiga0 Link encap:Ethernet HWaddr 00:50:43:02:02:01
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:193
egiga2 Link encap:Ethernet HWaddr 00:50:43:02:02:03
egiga0: mac address changed
Interrupt:195
Do Lan Port Switch
egiga2: mac address changed
not_egiga0: mac address changed
jnl: driver (lke_9.2.0 lke_9.2.0_r256412_b67, LBD=ON) loaded at bf000000
ufsd: module license 'Commercial product' taints kernel.
Disabling lock debugging due to kernel taint
ufsd:: trace mask set to 0000000f
ufsd: driver (lke_9.2.0 lke_9.2.0_r256412_b67, build_host("fsd-linux-bs10b"), acl, ioctl, bdi, sd2(0), fua, bz, tr, rsrc) loaded at bf020000
NTFS support included
exFAT support included
Hfs+/HfsJ support included
optimized: speed
Build_for__WD_Grand_Teton_3.10.39_2015-08-26_lke_9.2.0_r256412_b67
bio: create slab <bio-1> at 1
Btrfs loaded
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
lrwxrwxrwx 1 root 0 17 Sep 24 23:37 /usr/sbin//raid_config -> /usr/sbin/diskmgr
lrwxrwxrwx 1 root 0 17 Sep 24 23:37 /usr/sbin//raid_expand -> /usr/sbin/diskmgr
lrwxrwxrwx 1 root 0 17 Sep 24 23:37 /usr/sbin//raid_expand_disks -> /usr/sbin/diskmgr
lrwxrwxrwx 1 root 0 17 Sep 24 23:37 /usr/sbin//raid_update_info -> /usr/sbin/diskmgr
hardware init
pool #1: pkt_size=1536, buf_size=1600 - 2048 of 2048 buffers added
egiga1: link up
egiga1: started
pool #0: pkt_size=1536, buf_size=1600 - 2048 of 2048 buffers added
egiga2: link up
egiga2: started
mtd check v1.06.06032015
config mtd type is UBIFS
device = /usr/local/config
Total size = 12384 Kbytes
Used size = 156 Kbytes
Free size = 12228 Kbytes
percentage = 1
/usr/local/config free size is 12521472
** copy config files
*** Copy orion.db from flash ****
cp: can't stat '/usr/local/modules/files/fan_temperature.txt': No such file or directory
*** symlink onbrd.ini from flash ****
/etc/sysinit.d/wdlog: line 13: /etc/system.conf: No such file or directory
** set loopback interface
UBI: attaching mtd6 to ubi1
UBI: attached mtd6 (name "reserve1", size 10 MiB) to ubi1
UBI: good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
UBI: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 3010254962
UBI: available PEBs: 30, total reserved PEBs: 50, PEBs reserved for bad PEB handling: 12
UBI: background thread "ubi_bgt1d" started, PID 3407
UBI device number 1, total 80 LEBs (10158080 bytes, 9.7 MiB), available 30 LEBs (3809280 bytes, 3.6 MiB), LEB size 126976 bytes (124.0 KiB)
UBIFS: background thread "ubifs_bgt1_0" started, PID 3426
UBIFS: mounted UBI device 1, volume 0, name "reserve"
UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS: reserved for root: 143937 bytes (140 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID B0D9C490-8017-43A2-9583-C553F8B6C1B8, small LPT model
UBIFS: un-mount UBI device 1, volume 0
UBIFS: background thread "ubifs_bgt1_0" stops
UBI: attaching mtd7 to ubi2
UBI: attached mtd7 (name "reserve2", size 10 MiB) to ubi2
UBI: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1789194535
UBI: available PEBs: 20, total reserved PEBs: 60, PEBs reserved for bad PEB handling: 14
UBI: background thread "ubi_bgt2d" started, PID 3441
UBI device number 2, total 80 LEBs (10158080 bytes, 9.7 MiB), available 20 LEBs (2539520 bytes, 2.4 MiB), LEB size 126976 bytes (124.0 KiB)
mknod: /dev/mtd7: File exists
UBIFS: background thread "ubifs_bgt2_0" started, PID 3454
UBIFS: mounted UBI device 2, volume 0, name "reserve2"
UBIFS: FS size: 4063232 bytes (3 MiB, 32 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS: reserved for root: 191915 bytes (187 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 0219C956-060D-4A29-B3D1-40A896773638, small LPT model
/dev/mtd7 mount ok(ubi)
UBIFS: un-mount UBI device 2, volume 0
UBIFS: background thread "ubifs_bgt2_0" stops
mac1 = 00:90:A9:E8:A0:ED
lan0:ifconfig egiga0 hegiga0: mac address changed
w ether 00:90:A9:E8:A0:ED
pool #2: pkt_size=1536, buf_size=1600 - 2048 of 2048 buffers added
egiga0: started
set lan0 speed
[wd_read_serial.c:621] Read serial number from flash.
[wd_read_serial.c:160] serial number : **[Deleted - Trancer]**
Model ID : GT
GT
ln: /usr/local/model/web/pages/images/./icon: File exists
hidden encryption: 0
Not support chk_sata
old firmware ver:2.21.111.0629.2016
new firmware ver:2.21.111.0629.2016
rm: can't remove '/tmp/fix_wd_config': No such file or directory
*** execute rc.init.sh
awk: /var/run/udhcpc0.pid: No such file or directory
udhcpc (v1.20.2) started
cat: can't open '/tmp/setip.0': No such file or directory
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
init egiga0
[upnp_nas_xml.c() 348] Can't get IP of egiga0
Initializing UPnP Sdk with
ipaddress = (null) port = 0
Error with UpnpInit -- -208
killall: crond: no process killed
crond[3684]: crond: crond (busybox 1.20.2) started, log level 8
/usr/local/modules/script/system_init: line 866: getHddWhiteList.sh: not found
sh: you need to specify whom to kill
*** Copy CacheVolume data from flash ****
*** set Time Zone ****
$Usage: apache {start|stop|restart} {web/dav}
Sat Sep 24 23:37:48 PDT 2016
*** get Time from rtc and set it into system ****
rtc: RTC time = 2016/9/24 Sat 23:37:49
Sat Sep 24 16:37:49 PDT 2016
Set Date & time : sntp -K /dev/null -S -r time.windows.com
sntp 4.2.8@1.3265 Fri Jan 9 06:42:54 UTC 2015 (8)
time.windows.com lookup error Temporary failure in name resolution
Module IPC SERVER Version:(1.00.20090706)
ads=0
created mail daemon thread 0
POWER ON DEVICE!!
Up_Send_Ctl : Can not find specified command "ErrStatus"
mount: mount point /proc/bus/usb does not exist
WD hwlib start..............
Starting system message bus
Starting wdtms
wdtms started
PHY_LAN_NUMBER=1
BOND_ENABLE=0
VLAN0_ENABLE=0
VLAN1_ENABLE=0
I/O warning : failed to load external entity "/var/www/xml/internal_backup.xml"
cat: can't open '/var/run/traceroute_wd.pid': No such file or directory
ash: you need to specify whom to kill
--2016-09-24 16:37:53-- http://download.wdc.com/apps/WDMyCloudMirrorG2/WDMyCloudMirrorG2.xml
Resolving download.wdc.com... failed: Name or service not known.
wget: unable to resolve host address 'download.wdc.com'
killall: traceroute: no process killed
traceroute: bad address 'www.wd2go.com'
traceroute: bad address 'www.wdc.com'
-------------use hwlib instead of fan_control b c-------------
restart sysinfod...
sysinfod: full update begin...
sysinfod: disk connected: previous=0xffffffff, now=0x0
sh: getHddWhiteList.sh: not found
Set Date & time : sntp -K /dev/null -S -r pool.ntp.org
pool.ntp.org lookup error Temporary failure in name resolution
3868 root 3936 S avahi-daemon: running [ToasterOven.local]
config egiga0 169.254.229.6
RTNETLINK answers: File exists
call load_module network
Up_Send_Ctl : Can not find specified command "SysIP1"
Command line is not complete. Try option "help"
zcip: script /usr/share/udhcpc/zcip.script config failed, exitcode=1
waiting : [10]
mcu version 1.06
chk_io v1.04.20141112
system daemon v1.04.20141211
I/O warning : failed to load external entity "/var/www/xml/usb_backup.xml"
Sat Sep 24 16:37:59 PDT 2016 - %W - Communication Manager - startup is disabled, use 'enable' to start process
PIP is disabled, exiting.
dev.raid.speed_limit_max = 200000
Please press Enter to activate this console. sh: operate_auth: not found
killall: chk_hotplug: no process killed
Get_Cloud_Status
Starting wdmcserver
Starting wdphotodbmerger
WDPhotodbmerger started 0
Starting wdnotifier
wdnotifier started
killall: smbd: no process killed
Create USB dev node
rm: can't remove '/tmp/disk_uuid': No such file or directory
ls: /proc/4599: No such file or directory
ls: /proc/4600: No such file or directory
sysinfod: inform: all drives status=No Drives.
LED_POWER_ON
starting pid 4364, tty '/dev/ttyS0': '/bin/login'
Password of admin:
