Can you please point me at the correct location for these files for my WDMyCloud-Gen1?
I am running DSM but can’t seem to find them in the directory, I have tried downloading the file dsm-rootfs.tgz but am unable to locate the necessary files in it,
@Fox_exe (or anyone else can answer) sorry if already asked: i’m using the Debian chroot app on a mirror gen 2.
Is it safe to upgrade the WD firmware or will the Debian stuffs done will be lost? (packages, custom scripts/services registered)
i am already searching for about 2 weeks to unbrick my WD ex2 Ultra. But i cant get is.
Please help me!
First of all i want to make my Ex2Ultra to an Nextcloud Device.
Step one was to make it run a Debian system. I used this image and tutorial: https://fox-exe.ru/WDMyCloud/WDMyCloud-Ex2-Ultra/Debian-linux_4.14.4/
I uploaded the “Firmware-debian-linux-4.14.4.bin” with the the UI in my Browser as an Firmware and rebooted the NAS. After that its over.
Everything worked including step “set 3 raid on”"
after that i cant go on - I dont have disks named “/dev/sda1,2,3 or /dev/sdb1,2,3” Only /dev/md126 and /dev/md127.
Thx for your fast answer. I got it now. But i dont get nexcloud running as i want.
i think i want to try to bring the ex2ultra back to normal with original FW if this is possible ?
I already downloaded the GPL File form the WD page. But i realy have no idea which file i have to copy to which location.
I would be realy thankful if someone can lead me in the right direction, thx.
BTW.: the NAS ignores the USB to boot. I tryed it with drives inside or out and holding reset button during boot up for about 40sec.
EDIT.: I tryed the unbrick tutorial from https://fox-exe.ru/WDMyCloud/WDMyCloud-Gen2/ serveral times. The “normal” and the alternative way. The NAS always Boots up with the random MAC and i cant access the web ui. The uImage, uRamdisk and every other file or directory is always gone after a reboot.
Hey guys,
I’m also struggling with DSM on my WD EX2 Ultra…
I’ve installed the DSM from @Fox_exe 's page following his instructions and it kinda worked out. I was even able to get my real Synology to do Hyperbackup to this one over network. But then I tried to install Certificates of Let’sEncrypt and set it up to only use https and I guess that’s where I ■■■■■■ up.
Now the box connects and boots up, but only shows a white page in webgui - not even login screen, nothing.
I’ve tried to go back by pulling out the disks, but this also doesn’t help any more.
I’ve also tried to connect via Telnet - no chance.
I’ve tried the 40sec reset from WD - also nothing.
Any ideas how I could get it back to work (at least with WD FW)?
Poweroff, extract all disks, poweron.
Search in your network new IP/MAC address, connect via Telnet.
Install disks back, mount raid (mdadm -A), mount rootfs and replace damaged files (Download original files)
I’ve powered off, removed the disks, powered on again.
IP is still the same, Power-LED is blinking, when trying to connect via Telnet, Putty says “Network error: Connection timed out”
EDIT: Forced the router, to give it a new IP. After a restart, it took the new IP and remembered the name I gave it in the DSM, but still no webgui or Telnet.
I made a couple of changes, though:
1.) Encrypt with cryptsetup 2
2.) Boot from USB thumb drive (so that the disks can finally sleep using hd-idle)
3.) Decryption key on separate thumb drive
The image is the Debian stretch from fox-exe. But you can easily upgrade to buster after installation. Here’s a pretty good example:
At some point I had to use a serial connection because the image I created was faulty. But I think you can use an ssh connection too. That should work.
Somehow after power loss my WDMyCloud-Ex2-Ultra got bricked it had earlier Debian from Fox site installed. Now using uart I’m able to access it and I was following the guide Bricked my EX2. <Also how I unbricked it> - #9 by TCWORLD but I got stuck on “umount /dev/loop0” it shows
umount: /usr/local/modules: device is busy.
(In some cases useful info about processes that use
the device is found by lsof(8) or fuser(1))
Can any of you please advice me how to get back to either original firmware or bring back Debian alive, thanks.
