4T drive removed from external case and installed into PC to recover data
Hi
My friend dropped his external drive. The IT department has removed the drive and had some adapter to allow him to get access to drive. Worked for a while. He asked me for help.
I installed drive in my computer. It does not show up on MY PC. When I run Disk Manager , I get the following message
You must initialize disk before logic Disk Manager can access it
Use the following partition style for the selected disks
MBR or GPT
I selected MBR
Then I get
The request could not be performed because of an I/O device.
Then on the Disk Manager screen the disk is labeled Unknown.
I ran Western Digital Lifeguard tools and it passes both tests.
The drive also shows up in Device Manager as a hard drive and device working properly
Any suggestions ?
The drive model number is
WD40EZRZ-00GXCB0
Thank you in advance
I’m gonna guess it was a WD My Book ? correct ?
You can’t remove a hard drive from a WD My Book enclosure and put it another enclosure (or use an adaptor) to recover the data because the drive and it contents are hardware encrypted.
Initializing a Disk wipes / formats the drive erasing all data on it.
So, you selected MBR and wanted to erase all the data that you were attempting to recover ? ps. MBR only supports up to 2TB … GPT supports up to and over 2TB .
You don’t know what you’re doing.
Give the drive back to friend and tell them to Contact a Data Recovery Company that knows what they’re doing.
