1TB WD Elements Portable USB 3.0 Hard Drive Storage for iPad Air 2
Hello.  I’m wondering if the 1TB WD Elements Portable USB 3.0 Hard Drive Storage will work with an iPad Air 2?  I’m assuming it will since it seems to be compatiable with Mac devices in general.  Buti, I want to check first before purchasing it.  Thanks.
Hello there and welcome to the WD community.
The iPad is a device that does not have a USB 3.0 port on it, I do not know if there is a 3rd party device that would let you connect a USB 3.0 drive to an iPad. Lets see if there is another user that can help you out on this matter.
