As my MBL is nearly full, I decided to replace it with a MBL Duo.
I will use it mainly as a DLNA video server (I have a lot a video files recorded with my DVB-T recorder), and as a backup destination for my laptop files.
Then, could you please give me some answers / advices on the following subjects:
what is the most stable firmware for the MBL Duo as of today ? My MBL was running with fw 02.11.09-053
does the embedded DLNA server works correctly, or should I directly install twonky 7 (+ licence). On my MBL, I had no problem at all with the embedded twonky server.
So, I started my new MBL Duo installation this morning.
These are my first remarks, maybe yo can give me some info or will have some remarks about this:
upgraded to latest firmware => no problem
change network setting with a fix IP address => no problem
enable SSH => no problem
set admin password => no problem
create a Media share, with R/W access granted to existing user admin and brand new user media
=> 1st problem here, I am not able to access this share from windows using the admin user (but ok with the media user). After multiple tests, changing admin password, etc … I realize the admin user is not listed in the /etc/samba/smbpasswd file
I solve the problem with the following command: smbpasswd -a admin
then I plug a 2.5’ passport HDD to the MBLD usb port and start a copy of my video files (around 35mn for 50 gbytes with a simple cp -R, seems correct)
now, I test the embedded dlna server using my personnal media player connected to the TV
=> 2nd problem here: video length for .TS files is not correct (ex: a 2h movies is recognized as a 18mn movie).
It seems this problem only impacts .TS files (bad luck, 90% of my video files are .TS files)
So I decide to install twonky 7.0.9 to check if that solves the problem. The answer is yes, video length of my TS files is now correct.
My MBLD is now up and running since last saturday, and works like a charm.
I am using twonky 7 as DLNA server, and think I will buy the licence in the next few days, unless WD quickly corrects the wrong duration bug on .TS files.
