If you had OMV previously installed you removed this file: /etc/apt/sources.list.d/openmediavault.list and all mentions to it’s repositories in sources.list as well.
To issue a package update from backports you need to specifically request so. Quoting the Debian backports documentation:
“All backports are deactivated by default (i.e. the packages are pinned to 100 by using ButAutomaticUpgrades: yes in the Release files. If you want to install something from backports run:”
Current clean Debian Kernel kindly made available by Fox_exe (see first post on this thread) is missing some requirements to run iotop (bellow).
Could not run iotop as some of the requirements are not met:
- Linux >= 2.6.20 with
- I/O accounting support (CONFIG_TASKSTATS, CONFIG_TASK_DELAY_ACCT, CONFIG_TAS K_IO_ACCOUNTING)
Also, as someone suggested already, adding full iptables supports might be a good idea.
I know instructions are available on how to build and tweak your own custom Kernel. Still, I am sure for most picking the precompiled is the most viable option. So, perhaps Fox_exe can eventually give these suggestions some consideration for future builds.
Thanks a lot. Installed following your guide and IPTables are working fine.
It’s worth mentioning that the procedure for installing the new kernel can be done from within a running NAS. Just make sure you do things right, exactly as described, or it may not boot properly next time.
If you managed to remove OMV and Debian is sane perhaps you do not need a fresh install.
The main utility would be to get entirely rid of configuration files (and some packages likely, such as Nginx) OMV must have left behind.
Otherwise you can always use the purge option while removing a package to make sure configuration fles are deleted as well.
Also, while installing new stuff and given the option to either keep existing configuration files or replace/overwrite them by default package maintainer versions choose the second (it’s a good idea to manually do a backup copy as well, so you can compare them in the future in case you have problems).
If you are building a Media Server Plex could be a good option. Along with client apps for TVs (Samsung and LG) and mobile devices (which offer a neat interface and additional info and features for media files such as synopsis and automatic subtitles downloading ) and a webinterface, it includes a DLNA server which I have found affords quicker browsing and better organization than MiniDLNA.
Bear in mind tough that the MyCloud is a bit short on resources to run a Plex Server. It will work but expect periods where the system lags a lot with high loads and a lot of swapping (mostly when Plex is indexing files).
If you go the MiniDLNA way I found there is a package with latest 1.1.4 version for Debian armhf available from http://www.deb-multimedia.org/. It does use a lot of stuff from SID. I found no problems but one should always think twice before using SID. I managed to render the device totally unusable while performing some updates from SID before.
it seems that i really managed to get rid of openmediavault and related packages.
The plex media server installation seems to be too advanced for me to test in on the my cloud device directly. I have to play with chroot and bootstrap on PC first. So i have installed the minidlna instead. I tried the deb-multimedia.org but there was a problem with dependencies in standard debian packages and unstable deb-multimedia repository so i have decided to avoid inreversible mix of packages in the system and go with minidlna 1.0.24.
I also managed to instal Webmin. IMO WebMin gives minimal benefit for single-drive mycloud device comparing to the console. UI is too generic and not very intuitive. However, i will keep the Webmin for several weeks to give it a chance
I would like to say thanks for all the good hints i have found here
Webmin has been around for years mostly as a solution for managing webservers and for overall system administration. It is not specifically geared towards home solutions.You can nevertheless better extend it for that purpose by using third party modules such as MiniDLNA Webmin Module.
MiniDLNA v. 1.1.2 versus v. 1.0.24 adds a better handling of the way content folders are organized. 1.1.2 versus 1.1.4 seems to notoriously add the following option which is useful if you want to serve mediafiles say from a camera, mixing photos and videos:
# + " PV" for pictures and video (eg. media_dir=PV,/home/jmaggard/digital_camera)
As for installing Plex, the bitbucket how-to guide is sound. It will work as it is, although I would suggest installing the chroot outside of the system 2GB partition because of size (the wheezy-armel chroot + Plex amount to as much as 400MB of data).
My device isn’t booting - the two red LEDs are flashing intermittently.
However, when I install the upgraded firmware it looks as if it is booting OK from the SD card.
Can I compile it from source into a bootable binary on the SD card that then installs itself?
If you haven’t tried it, have you an idea of where I should start? The Firmware boots from:
MyPassportWireless_1.03.13.bin
If you put it on the SD card in a directory called ‘update’.
Presumably one way to get it to would would be to replace the above .bin with a compiled binary, then boot it from the SD card - and then login to move install linux where it’s supposed to be.
Is there an easier way you can suggest?
I’d imagine that, at WD, when a broken device comes in, they pop an SD card in and boot from that, it’d make sense, then they can run diagnostics etc, without disturbing the other volumes. I imagine that’s how they recover data.
That looks a possibility - if you boot from the SD card, there’s clearly some sort of ROM based OS that runs. Do you know if that system has ‘tar’ ‘cp’ and ‘dd’ in it? If it does, then a script that does what you suggest below should do the trick.
Is there an easy way to build a bootable .bin file for the SD card? I see it has to have all the .md5 signatures correct, but, presumably, that’s to make sure that it’s not corrupted, not to prevent anybody from making a similar bootable binary.
#./boot
sata # initialize SATA
sataenv run 7 # try to run script from partition 7
sataenv run 8 # try to run script from partition 8
. /env/bin/boot_sata # if all else fails, use this script to boot
Normal boot script commented, so no possible to boot from any other device except sata. Sorry.
#./boot
Partition 7 is the DataVolume partition, I think - what is partition 8? Is it the SD card?
But the firmware is installed from the SD card by booting from the ‘update’ directory.
Do you have the source of /env/bon/boot_sata — It must have a provision for booting from the SD card.
i have installed the plex media server. I am still wondering how it is possible that it works with mixed armel/armhf architecture. It seems that armhf is backward compatible;-).
However, OS died while plex indexing large number of files. I am not sure whether it runned out of memory but at the end OS stands still :-(. I stopped all my services to spare some memoty and tried again, but it did not help. I am thinking mounting the tmp to the HDD. I am not sure whether plex media server uses the tmp folder but when it does it might eat all the RAM. Didi you do some tweaking to make the plex server really working?
ARMHF - Floating point instructions works at hardware (No emulation)
ARMEL - Floating point instructions emulated programmatically.
There is no difference between armel/armhf (but hf works faster)
