I have followed all of the instructions, and added newest openmediavault, and now I no longer have ssh access. I get connection refused. How can I fix this?
I would like to sync the folder with google drive. I did not find plugin for this in openmediavault. Have anybody tried to sync with google drive in wheezy? Which tool do you use?
thanks, i have tried grive but had a problem with mixed dependencies. I was not able to resolve them.
The following packages have unmet dependencies:
grive : Depends: libboost-filesystem1.55.0 but it is not going to be installed
Depends: libboost-program-options1.55.0 but it is not going to be installed
Depends: libgcrypt20 (>= 1.6.1) but it is not going to be installed
Depends: libstdc++6 (>= 4.9) but 4.7.2-5 is to be installed
E: Unable to correct problems, you have held broken packages.
The problem is: this won’t work with openmedivault installed as the OS will give preference to the OMV repository and dependencies no matter what.
OMV leaves you stuck with a bunch of outdated stuff and is a bit of a disappointment as far as I am concerned,
You would be much better off by removing it and installing Webmininstead, which offers a more powerful, comprehensive and reliable GUI for administering Debian.
To remove OMV one can try:
apt-get purge openmediavault
apt-get autoremove
Sadly this will still leave behind a bunch of configuration files tweaked by OMV which may be problematic with subsequent package installations.
To install Webmin one can follow these instructions:
Bottom line for first time fresh installers is: FORGET OMV. Just install a clean Debian and if you need a Graphical Interface for administration use Webmin.
OMV-PyLoad installs fine whereas if you try to install it from Debian repositories or manually you may stumble on a serious issue pertaining GNUTLS
Points against OMV:
A bunch of critical packages are outdated and lack functionality, namely: MiniDLNA (old version does not organize shown folders as well) , Aria2 (uses a buggy version) and OwnCloud (v7 allows communicating with other OwnCloud installations, OMV uses v.6 and the maintainer has an “attitude” which affords it little priority)
Installs Nginx by default. This conflicts with many packages you will find in Debian Repositories which use Apache instead.
For the sake of it’s own integrity it prevents installation from other sources and actually reduces your freedom of choice. In the end you get a deliberately simplified interface which does not handle - and worst prevents you from handling - more granular settings.
For anyone trying to elude a manufacturer’s custom Kernel, OMV will corner you in a different way and does not seem the way to go.
BTW, the nice system performance graphs OMV offers (for the utility they may actually have) can be easily obtained by using any of these collected front-end tools
I tried updating to Samba 4. I noticed in /etc/samba/smb.conf there were several things not in that file that were on the list of things to edit. I added them and restarted samba, and now it’s not working. anyone now why?
