My WD TV was working fine. but now it wont turn on. Changed the batteries in the remote but still wont power on. Is there a way to power on without the remote?
Welcome to the forums.
This is the Live/Plus forum – if you have a WD TV (not a Live) you should post in that forum.
For the Live if you simply unplug it and plug it back in it will turn on by default.
