Hi All!
I’m new to this forum.
Has anyone been successful in connecting Live Hub to the network using a USB adapter.
I know there’s a list of compatible devices, but which one works best?
i was using a belkin F6D4050 V1 that worked perfectly, i went lan direct in the end, im actually selling the belkin now
Why do you prefer LAN over wi-fi?
My problem is that my router is not in the same room as my home theater where I place the Live Hub, thus I will have to use a long LAN cable.
because my router is in the same room as the hub, but i can see where your coming from, lan cable is cheap though
Thank you.
no problem, glad to help
Because transfers are slow using wifi and using it to watch high-def content or Blu-Ray rips is next to impossible for most people. If at all possible, go wired. Even Powerline adapters are better than a wifi adapter in most cases. If you must go wifi make sure it is wireless N or AC for the fastest possible bandwidth.
i agree it is faster after trying both…smooth
Thank you.
Thank you all.
