i am using Wireless Pro 3TB for 1 month and it has been working fine. However, now when I turn on the device, the wifi led will blink for about 10 seconds and shuts down on its own. I am unable to connect it wirelessly. I tried manual restart but it has not solved the problem
Hi IrwinCua,
The link below will allow you to call support if you are having trouble with the form.
