I just bought the WD MyCloud 3T today, it works at first. Then I upgrade the firmware to 4.0.
After upgrade, I open SSH, go inside, run
apt-get update
apt-get upgrade
and it has some error. I can’t understand what is the error mean. Then I do reboot thru the dashbroad, no reboot happened. And finally I unplug and plug in again and it stays white LED.
Then I read manual, see how to reset, as it mentioned:
press reset button while power on, only reset password. I tried and still solid white LED no connection could be made
press reset button before power on, and keep pressing for 40 seconds (I did this for over 60 seconds), it still can’t boot up and no connection. Always solid white LED, the LED lit off for 0.5 second oscationally and gets back to solid white LED.
Can anyone tell me what to do? This is very frustrating. Thanks.
