Webinterface not reachable after Firmware Update
Have the same WDBCTL0040HWT-00 enclosure. It was initially a 4T My Cloud that came with an early version of the v4.x firmware. Internal 4T drive got damaged so I replaced the drive. First ran a 250G drive in it, then a 1T drive.
Here my 2 cents:
Ever since I had bought a Western Digital My Cloud System with 4 TB of Backup space, I had problems with it: after some hours, the system was unreachable over the network. Several firmware upgrades later, the problem has aggravated, and the system was reachable only for 10 to 20 minutes after powering it on.
In my blog post Resolving Networking Problems (Performance Problems) of a WD My Cloud NAS System - I have summarized the measures I have taken to get it back to life.
In short: by enabling SSH and using top, I have found out that the system was in a heavy swapping mode because of missing memory, which had caused the problem on my side. I also could see that the system was spawning 10 apache2 processes, which were consuming almost 100% of the physical memory, so other processes were starved.
As a resolution, I have changed the number of apache2 processes to a reasonable number (3 in my case). Since then, the disk is silent (it was working heavily and audibly before), and the web interface responsiveness is higher than ever before.
To perform the changes, log in per SSH as root, edit the file /etc/apache2/mods-available/mpm_prefork.conf.
Before the change, I have found following relevant content in the file:
StartServers          2
MinSpareServers       2
MaxSpareServers       10
MaxRequestWorkers     10
MaxConnectionsPerChild  10000
I have changed this to:
StartServers          2
MinSpareServers       2
MaxSpareServers       3
MaxRequestWorkers     3
ServerLimit           3
This was the resolution that had helped in my case; a resolution I have not found in any of the Forum posts.
I hope this is useful information for someone.
is it possible to shrink a 1TB Image “factory Default” to i.e. a 500GB HDD?
I would shrink the big data partition to about 450GB and copy the Image via following command
“dd if=/dev/sda of=/DataVolume/shares/Public/mycloud1tb.img bs=1M count=5000”
Afterwards i would restore the Image to a smaller hdd.
Thank you very much!
Best regards
Zuendapp
If you are unbricking and replacing the older first generation v3.x/v4.x single bay My Cloud hard drive with a different hard drive (including one that has a different size) there is no need to “shrink” the drive. Just follow the directions to properly partition the drive. Once unbricked generally one should run a full system reset (40 second reset via reset button on the back of the My Cloud or a System Restore through the Dashboard > Settings) to correct the incorrectly reported hard drive size.
See the following link by user Fox_exe that details how to “unbrick” a first generation v3.x/v4.x single bay My Cloud unit:
English: https://drive.google.com/file/d/0B_6OlQ_H0PxVbzZac0plbkZKeGM/view
Russian: https://drive.google.com/file/d/0B_6OlQ_H0PxVakNZMjFvdzloRVk/view
Those directions have a slightly different method of fixing the incorrectly reported hard drive size post unbricking.
Hi Bennor,
nice Tutorial :), but the links (Google Drive) are down.
Do you have the tar.gz Image Files?
Thank you very much
Best regards.
That’s one of the problems with many of the unbricking procedures, finding valid links to the files needed. You could try using either the v3.x or v4.x file Fox_exe has up in the Backup folder of the Google Drive that hosts those instructions: https://drive.google.com/drive/folders/0B_6OlQ_H0PxVNTN6c2F4SXEwQVU
Hi Bennor,
Thank you very much! It worked with the V3… backup. How can I make a Backup of my (kernel.img, rootfs.img, config.img) to play back a Image with the newest Version?
Best regards
A subforum search, using the magnifying glass icon upper right, for creating a backup img file brings up several threads…
http://community.wd.com/t/how-can-i-make-the-virgin-disk-imgae-of-my-cloud-2tb/91142/5
http://community.wd.com/t/unbrick-with-clean-03-04-01-230-bittorrent-firmware/93261/16
The command goes something like this to save the img file to the Public Share on the first generation single bay v3.x/v4.x firmware My Cloud:
dd if=/dev/sda of=/DataVolume/shares/Public/mycloud.img bs=1M count=5000
Note: You probably want to do this on a My Cloud that doesn’t have any user data copied to it yet and you probably want to do a 40 second reset via the reset button on the back of the My Cloud, or use the Dashboard >Settings > Utilities > System Restore to reset the My Cloud to default values, or use the Dashboard >Settings > Utilities > Quick Restore which erases all user data and resets the My Cloud to default.
Hi :),
I have tried it this way:
Works nice! Thank you!
Best regards
Zuendapp
Hi All, I came across this thread and I am confused.
I have a WD My Cloud with a single drive of 2 TB. I want to replace it with a 4 or 6 TB drive.
What do I have to do ? Is there a clear 1,2,3 steps listed anywhere. I saw all sorts of posts regarding all sorts of models and various steps.
I know a little scripting and ssh is not a stranger but would rather do this the Windows GUI way if possible.
Is there a procedure I can follow?
Many thanks and sorry for reviving this old thread.
T.
There are a number of thread discussions that cover replacing or changing the My Cloud hard drive with another hard drive. Any of the unbricking procedures will work when replacing the My Cloud hard drive.
As indicated earlier in the current thread discussion user Fox_exe has created a set of directions for unbricking a first gen (v3.x/v4.x) single bay My Cloud and a different set of directions for unbricking the second gen (v2.x) single bay My Cloud.
First Gen: https://drive.google.com/drive/folders/0B_6OlQ_H0PxVZTBtM3EyRVhDVms
Second Gen: https://drive.google.com/drive/folders/0B_6OlQ_H0PxVRXllYjY5RG1CZEU
