good day all i’m new here
i just want to ask something about downloading the advance
http://support.wdc.com/product/downloadsw.asp?sid=128&a=
i want to download it but i have a problem registering :cry:
i dont have extension phone
What windows do you have ?
If you have installed windows 7 you are fine formatting the drive in windows
you dont need that software if is the case above
