Hello! I have a problem on my ipad1 with programs WD2go, WDPhotos. I can not go through a local network at MBL and I can not see the files and photos.With 3g everything is OK and I can see their files on the MBL. In my local network using router dlink dir-320. I hope to help, thank you.
upd.
D2Go and WDPhotos begins to run on the local network after restarting ipad and after a while stops again. We also note that the connection status does not change even though the unit sees the files and shows all the time show waiting.
upd
After experimenting, I can only assume that the problems with the connection on the LAN associated to the router’s configuration that is “upnp” setting after turning off the “upnp” connection to work.
