You must use Windows XP sp 1 home edition for Caviar Green HDD because The speed of Caviar Green is 5400 Rpm if you still use Windows 7 the hardisk will be broken and damage. Or you can buy Caviar Black this month.
Xfander wrote:
You must use Windows XP sp 1 home edition for Caviar Green HDD because The speed of Caviar Green is 5400 Rpm if you still use Windows 7 the hardisk will be broken and damage. Or you can buy Caviar Black this month.> * * *> thank you for your comment…> my hdd is WD20EARS and features :> Caviar Green WD20EARS Internal 2TB 3.5” Hard Drive (SATA, 7200 RPM, 64MB) > so speed is not 5400 Rpm. maybe different reason broke my hdd
if your data is important then stop using the hdd and buy new hdd and backup your files asap, once the problematic hdd go out of your hand then recovering data is very hard, ask me i have lost my data 2 times becuz i never used to backup my data, now i bought a 2TB hdd and thinking to buy a external 2TB so i make backups.
your hdd is not 7200 speed, i have done a lot research on WD hdds, all the new [green] hdd wd are 5400 speed
thank you.
yes i stopped my hdd and i start again and i will try hdd life then later send the result
the hard disk sentinel is the best program to rely on, if it says problem, there is in it.
buy new hdd and copy your data and RMA your failing hdd if possible.
i bought this WD2001FASS, and used wdidle3.exe, [[the LLC happen after 300 seconds[5 mins]…wdidle3 cannot disable the LLC…]] + 7200 real speed and fast read/write speed, sata 2 most computers, sata 3 not yet i see in computer so buy this WD2001FASS, i recommend it to you, i bought 2 off ebay brandnew, 5 year warranty on each.
WD2001FASS is [not] advanced format and can run xp / vista / win7… no problem
xp does reconize it, i think xp cannot [over] 2TB i read somewhere i am not sure.
remember to fix the idle3 timer otherwise the hdd will not last long like before the one u had it. timer3 is the thing the LLC does every 8/12 seconds which is very trouble and can cause problem with the hdd, the wd did no good making such LLC but company you know what can we do, their wish what they want, as buyer the wdidle3.exe does the job otherwise i wouldnt recommend wd for over 500 gb hdds… [the 500 gb wd black work very nicely without fixing anything, the LLC and other stuff no problem at all…it is over 120 days no problem]
u know the blackup of 1st hdd… this way you are protected against many things
1 thing…u should disable in device manager the 2nd hdd after backup if it is internal becuz if your 1st hdd get virus and it spread then u know it can go to 2nd hdd also…
the external one is best solution…
it is data that concerns all of us u know, if u spend little extra on it then u have peace of mind.
another solution burning to dvds but problem when updating…
but most important data that not needs update like pictures of family…dvd more reliable…i hear it can last 10years if good quality disc like verbatims…verbatim dvd-r the best. the dvd+r and cd-r / cd-rw have issues though.
sorry i thought i had posted the links but checked no yet… i have mix info that i did research now u research, dont panic though like me , there are solutions if u try to struggle…
SecurePark - Parks the recording heads off the disk surface during spin up, spin down and when the drive is off. This ensures the recording head never touches the disk surface resulting in improved long-term reliability and increased drive protection when the chassis is moved
The second level of cache (L2 cache) is where the L1 cache pulls in information from. L2 cache is slower than L1 cache, but is more affordable and can be much larger than L1. With the exception of L3 caches mentioned above, this is the cache which pulls information in from main memory. http://uk.answers.yahoo.com/question/index?qid=20101004065011AAH3V9r
dont buy sata3… u need sata 3 motherboard also to support it like usb 3.0…usb 3.0 will still work 2.0 if computer no usb 3.0 inside it…
i have another info to share with u
do u know the computer consume less than stated PSU…power supply…older pc consume more.
i checked my desktop computer using a electricty monitor…it showed around 100 watts just the tower…pc …while i have 350watts PSU in my pc…
the laptop showed like around 20-30 watts while it has 65watts power supply…
cool info yea?
it is real info i checked by myself.> * * *
i know this information my friend has to give him electricty monitor but he did’t give and i dont check my computer and laptop psu value so i dont know my electricty value
i have 1000W PSU and my Motherboard support usb 3.0 and sata3
